spanishfudge Scooter Rider
Number of posts : 25 Age : 62 Location : Antas, Almeria, Spain Points : 2203 Registration date : 2018-12-21
| Subject: coolant check Sun Mar 17, 2019 3:54 am | |
| hi guys, just going to check and clean the wing and i know where the coolant is but how do you check the level thank you will post my photos when i have clean it |
The Bern Silver Wing Expert
| Subject: Re: coolant check Sun Mar 17, 2019 9:24 am | |
| Get a torch & look upwards with your head by the mudguard/fender & you'll see the level in the expansion tank |
| Subject: coolant check Sun Mar 17, 2019 12:21 pm | |
| cheers for that will get new batteries for the torch |
janitorj1 Maxi-Scooter Rider
Number of posts : 104 Age : 71 Location : Folkston, GA Points : 3855 Registration date : 2014-09-07
| Subject: Re: coolant check Sun Mar 17, 2019 2:35 pm | |
| I don't know what they call "torches" in Spain... |
| Subject: Re: coolant check Sun Mar 17, 2019 2:58 pm | |
| Over here, they're called flashlights. But I suspect you all know that.
A torch is for welding and burning.
Jon
Have a great day. |
| Subject: Re: coolant check Sun Mar 17, 2019 5:53 pm | |
| To access radiator cap you need to pull out right storage pocket. It's easy enough to remove. Expansion tank is a good indicator of level but if it's empty you need to remove Rad. cap to really check it. U-tube SW coolant change will show you how. |
