| Battery Tender volt checker... | |
+4model28a bigbird MikeO dwoodul 8 posters |
dwoodul Scooter Rider
Number of posts : 72 Age : 74 Location : Dallas Points : 3789 Registration date : 2014-08-20
| Subject: Battery Tender volt checker... Sun Sep 14, 2014 9:13 am | |
| Many of you may have battery-tender pigtails for easy/quick charging/storing. I found, in this case on Amazon, a battery-tender plug in that you attach to the pigtail and it lets you know what the voltage levels are. It's $15 and real handy. We already found the battery/charging voltage low (11 volts and change...) on my sons VLX, did some rectifier connection maintenance, and surprise, the battery-tender read 13.8... yea!
On Amazon: Battery Tender 081-0157 Black Quick Disconnect Plug with LCD Voltage Display - Attachments
- (5 Kb) Downloaded 53 times
| Subject: Re: Battery Tender volt checker... Sun Sep 14, 2014 9:19 am | |
| I plug mine into the socket in the left-hand cubby. |
| Subject: Re: Battery Tender volt checker... Sun Sep 14, 2014 9:28 am | |
| There's a socket there...?? I better read my manual more closely. Thanks...!! |
Number of posts : 2387 Location : Winnipeg Points : 7872 Registration date : 2010-05-02
| Subject: Re: Battery Tender volt checker... Sun Sep 14, 2014 2:45 pm | |
| - dwoodul wrote:
- There's a socket there...?? I better read my manual more closely. Thanks...!!
You won't find a socket in yours unless it was added by a previous owner as an accessory. N. American Swings do not have that socket as standard equipment like Euro spec Swings do. |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7523 Registration date : 2010-02-03
| Subject: Re: Battery Tender volt checker... Sun Sep 14, 2014 3:03 pm | |
| Here is a link to the Battery Tender Voltage Display.
Digital Voltage Indicator with LCD Display |
lcgraham Scooter Rider
Number of posts : 18 Location : Albuquerque, NM Points : 3595 Registration date : 2015-01-07
| Subject: voltage check Thu Jan 08, 2015 4:17 am | |
| - dwoodul wrote:
- Many of you may have battery-tender pigtails for easy/quick charging/storing. I found, in this case on Amazon, a battery-tender plug in that you attach to the pigtail and it lets you know what the voltage levels are. It's $15 and real handy. We already found the battery/charging voltage low (11 volts and change...) on my sons VLX, did some rectifier connection maintenance, and surprise, the battery-tender read 13.8... yea!
On Amazon: Battery Tender 081-0157 Black Quick Disconnect Plug with LCD Voltage Display I use something similar, also at Amazon (Optimate TecMate battery tester). more expensive ($35+), no pigtails. Clamps directly to battery posts |
Number of posts : 4211 Location : York, North Yorkshire, England UK Points : 9404 Registration date : 2010-11-16
| Subject: Re: Battery Tender volt checker... Thu Jan 08, 2015 4:03 pm | |
| On the UK FJS Silver Wings you simply fit the supplied 12v plug to the Optimate lead and into the 12v socket inside the left glovebox pocket. I keep mine hooked up all the time. |
vader1701 Maxi-Scooter Rider
Number of posts : 106 Location : Auburn Hills, Michigan Points : 3724 Registration date : 2015-01-07
| Subject: Re: Battery Tender volt checker... Fri Jan 16, 2015 9:23 am | |
| Now that's pretty cool going to order me one, good monitor |
Scootn56 Scooter Rider
Number of posts : 17 Age : 68 Location : N.E. AL. USA Points : 4273 Registration date : 2013-02-23
| Subject: Re: Battery Tender volt checker... Tue Jan 20, 2015 11:02 pm | |
| Just received my Battery Tender 081-0157 Black Quick Disconnect Plug with LCD Voltage Display today from Amazon. My Goldwing battery was spot on just above 13V just like it was supposed to be. My Reflex battery was another story. I have noticed for some time now that even with the battery tender hooked up the battery would still occasionally discharge. When I hooked up the new tester I found that it did not even register, I had a blown fuse in the Battery Tender lead and it wasn’t even getting charged. Getting new fuse tomorrow. Many thanks to everyone on this forum for all the helpful information. |
