BoosterPlug Honda FJS600 Silver Wing
PRODUCT NUMBER: HONDA-6191
Price for 1 pcs. 159,95 USD
DELIVERY: Item is in stock and is shipped in 1-2 days.
AMOUNT
BUY
The BoosterPlug is the smarter choice, when you want to improve the rideability on your Honda FJS600 Silver Wing without spending a fortune.
Did you think the complicated Power Commander was the only way to sort out the fuel injection on your bike ? The BoosterPlug will offer the better solutiona at a fraction of the cost.
No complicated mechanical work or programming is required when installing the BoosterPlug. You simply plug it in using the original connectors and you are done.
Inexpensive, easy installation, proven results:
- Improved and softer throttle response
- Stronger acceleration
- The end of the dreaded low speed surging
- Removes the weak idle and stalling issues
- Minimize the backfire in your aftermarket exhaust
This version of the BoosterPlug covers all versions of the Honda FJS600 Silver Wing.
General Installation Instructions
Bike Specific Installation Instructions
BoosterPlug ApS | Slotsgade 3, Nysted, DK-4880 | Tel: +45 2080 7500 | info@boosterplug.com | Sitemap | Facebook page
I installed a Booster Plug on Friday and gave a good test ride on Saturday. Easy to install remove right rear side panel for access to air intake sensor. Plugged it in zip tied box to frame and put temp. sensor in air filter intake.
Sensor changes the temp. and fools the Computer to richen up mixture.
I feel it made a positive change. Runs smoother at idle and accelerates better MY opinion.
Measured miles per gallon on return trip 164 miles 2.521 gallons = 57.91 My mileage is about same as before. Mixed 40-60 back roads-highway. BUT with better power and driveability.
A good day for a ride low 70's and nice. 230 miles total.
