At the tire changing class with the Harbor Freight tire changer there
were a lot of people who needed their tires changed ... so I did not
take take any pictures of these steps.
Tools:
8 MM allen hex
22 MM socket
Torque wrench
Grease (I used Mobil 1 Synthetic Grease)
Phillips screwdriver -or- equivalent to fit axle bar holes on right side
Removal
1) Place Silver Wing on center stand
2) On left (axle bolt) side - Loosen (do not remove) the 8MM allen hex axle holder bolt
The axle holder bolt faces the ground behind the axle bolt, I laid on the ground to loosen
3) On left side - Loosen 22 MM axle bolt
4) On right side - Loosen (do not remove) the 8 MM allen hex axle holder bolt
5) Support the scooter using a hoist or motorcycle jack
We used a motorcycle jack under the front fairing because it required VERY LITTLE lift to raise the front wheel
6) On left side - Remove 22 MM axle bolt
7) On right side - Pull the front axle out and remove the front wheel
We used a thin phillips screwdriver to fit in the holes to help turn and pull the front axle out
DO NOT USE FRONT BRAKE PAST THIS POINT
(To prevent closing the brake pad gap)
9) Hold tire (to prevent damage to the disc brake and ABS sensor) and carefully raise the front end till wheel clears fender
10) Remove tire
11) Remove the left AND right side collar from the wheel hub
I stored the side collars separately so they could be installed on the same side later
12) Optional: Inspect brakes
13) Optional: Inspect air valve condition
Installation
1) Wipe with clean lightly damp cloth
- Side collars
- Front axle
- Inside wheel axle area (careful for the dust seals)
2) Clean brake disc
Ensure no residue
3) Grease the side collars and install into the wheel hub
4) Install the front wheel while carefully inserting the brake disc between the brake pads
Becareful for the brake pads and ABS sensor
5) On right side - Grease the front axle and install
May have to move the wheel to align the front axle while it slides in
The front axle should be flush with the left side
6) Clean an excess grease from all areas.
7) Lower hoist or motorcycle jack
On left side - Install and tighten the 22 MM axle bolt (59 Nm or 43 lbf-ft)
9) On left side - Tighten the 8 MM allen hex holder bolt (22 Nm or 16 lbf-ft)
10) With the front brake applied, pump the fork up and down several times to seat the axle and check brake operation
11) On right side - Tighten the 8 MM allen hex holder bolt (22 Nm or 16 lbf-ft)
12) Remove from center stand
and test drive brakes
