| Wiring up Spotlights | |
GoonerKev Silver Wing Rider
Number of posts : 409 Age : 70 Location : Reigate, Surrey, UK Points : 2510 Registration date : 2019-04-09
| Subject: Wiring up Spotlights Wed Apr 24, 2019 2:34 pm | |
| Today I fixed some new spot lights on the underside of the front fairing above the mudguard, found a live feed (when ignition is on) behind the front "V" it was a White wire & I think it is fed to headlights from what I could see. Found a nice earth also and connected the spots up, switched on ignition as I did in the test (when looking for a live feed when ignition is on) and...............you guessed it the 15 amp headlight fuse blew. Now I know I should use a relay but my brain is getting old and cant remember how to wire a relay up in order to do it right. These are the spots
https://www.ebay.co.uk/itm/2-x-Motorcycle-Motorbike-LED-Spot-Lights-Fog-Driving-Light-Daytime-Running-Light/223383372179
Kev |
Number of posts : 200 Location : Ocala, FL Points : 3683 Registration date : 2015-05-21
| Subject: Re: Wiring up Spotlights Wed Apr 24, 2019 9:48 pm | |
| Those lights should not blow the fuse, you might have a short. I had 4 of them running from the headlight connector without issue.
The way I connected them was with a 4" headlight harness extender, also on Fleabay. |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 4:20 am | |
| Thanks Sidewinder Pilot, I am going to get a Relay unit today to see if that will work. |
The Bern Silver Wing Expert
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 5:52 am | |
| Nah, relay will make no odds bud, you've got it wrong somewhere, did you connect the red or the black off the lights to the white off the loom ? I'm fairly sure that the lamp body is eathed on those is earthed, so wiring incorrectly with the lamps mounted directly or indirectly on any earthed part of the bike will blow the fuse.
White is live feed to dip beam .......... connect to red off lamp
Green is common earth ................... connect to black off lamp |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 5:57 am | |
| The Bern Top man, thank you so much for that info, it was doing my head in (done it so many times years ago but went "Blank") I love this Forum, thanks again |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 9:53 am | |
| TROUBLETriple checked connections. Red from Spots to "White" on Dipped wire Black from Spots to "Green" wire on Dipped wire 15amp Headlight fuse keeps blowing (3 now) So I connected the Red from spots to the wire feeding the Heated grips I put in last week and they worked perfectly, and POOOF the whole bike is dead now, no ignition lights on at all, gone through every fuse under the seat and put in identical one to match it, still bike is dead as a Do-Do, are there anymore fuses anyware please. Thanks in advance Kev |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 10:09 am | |
| Breedin' Nora bud, I'm guessing you must have an internal fault on at least one of those lights Yes there is a 30 amp fuse hiding behind the left hand body panel, give me a couple of min's & then check your PM inbox |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 10:13 am | |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 10:16 am | |
| Should be with you now Kev might help with dianosing this :Happy Holiday: |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 10:22 am | |
| On it, many thanks Bern |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 10:53 am | |
| All done, it was the 30amp fuse behind the left side panel, lucky there was a spare in the slot. Many thanks to Bern for his help on this problem. |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 12:59 pm | |
| You're most welcome Kev, on here we all try to help each other when we can, it's what we do bud :Happy Holiday: |
| Subject: Re: Wiring up Spotlights Thu Apr 25, 2019 1:05 pm | |
| I'm learning that Bern, I will re think the Spot Light problem, the thing is that they work perfectly straight from the battery, so I may end up wiring from there via a fused relay and a switch, not ideal but that's life. Many thanks again mate, appreciate your help.
Kev |
| Subject: Re: Wiring up Spotlights Wed May 01, 2019 4:08 am | |
| Subject: Re: Wiring up Spotlights Wed May 01, 2019 2:47 pm | |
| Subject: Re: Wiring up Spotlights Sun May 26, 2019 3:19 am | |
| "Red from Spots to "White" on Dipped wire Black from Spots to "Green" wire on Dipped wire"The spots have blown their 10amp fuse again, which I put inline !!!. They were working fine for over a week then went again, it's got me beat on such a simple job. Either the spots are faulty (in which case, surely they would blow straight away) or the Bike does not like them |
| Subject: Re: Wiring up Spotlights Sat Jun 08, 2019 2:35 pm | |
| All sorted now, found that a line from the right hand side light had come away from the live feed (crimp and heat shrink), re-done and fitted a switch to it as well (only works with headlights on) with a fuse to be safer. |
| Subject: Re: Wiring up Spotlights Sun Jun 16, 2019 5:11 pm | |
| Subject: Re: Wiring up Spotlights Sun Jun 16, 2019 5:39 pm | |
| - GoonerKev wrote:
- Think I may just wire them up straight to the battery via the switch and have an inline 15amp fuse !!!
Please don't, Kev. Wire them up thru a relay: Hot wire from the battery thru the relay to the fused line to the lights. Trigger the relay via your existing "Red from Spots to White on Dipped wire". Or, you could replace that fuse box 15 amp fuse with a 20 amp and be done with it. Tim |
| Subject: Re: Wiring up Spotlights Sun Jun 16, 2019 5:53 pm | |
| Tim Thanks for the reply, there must be something about that "White" on the dipped that the spots don't like as its blown fuses before. OK I have a relay in the shed (new), I will put that inline then as you suggest, I also have one of those re-settable 15amp blade fuses. I will give it one last try sometime in the week but if the fuse goes again then the lights go in the bin Kev |
