| Hi Beam Break Out Connector | |
ehaughn Maxi-Scooter Rider
Number of posts : 131 Age : 56 Location : Norcross, GA Points : 5491 Registration date : 2010-06-13
| Subject: Hi Beam Break Out Connector Tue Nov 30, 2010 10:05 pm | |
| Hey All,
Hope all is well.
I finally got around to building my hi-beam break out connector.
With the hi-beam switch turned on, I can toggle between using the hi-beam and auxiliary lighting.
Now that I have the wiring figured out, I hope to chose some LED's.
See attached diagram.
Also, can someone tell me how to embed an image? - Attachments
- Break-out wiring harness
- (115 Kb) Downloaded 67 times
| Subject: Re: Hi Beam Break Out Connector Wed Dec 01, 2010 10:28 am | |
| Nice job!!
Were you able to purchase that (male) 'plug into high beam connector' for the wire harness? I've seen the H7 (female) headlamp connectors at Pep Boys & Advance Auto, but have never seen that male plug available -either in an H7 or regular 2-3 wire headlamp format.
I assume that that connector is the 12V power-in point for this aux circuit.
joncallihan Silver Wing Guru
Number of posts : 1025 Age : 86 Location : Lafayette, Colorado, USA Points : 6931 Registration date : 2009-02-16
| Subject: Re: Hi Beam Break Out Connector Wed Dec 01, 2010 11:56 am | |
| Try these folks -- they are very helpful
http://www.oregonmotorcycleparts.com/index.html |
| Subject: Re: Hi Beam Break Out Connector Wed Dec 01, 2010 4:11 pm | |
| Here is where I got all the parts from
5 Pin Relay and Harness - And it's waterproof http://www.allelectronics.com/make-a-store/item/RLY-351/12V-SPDT-30-AMP-AUTOMOTIVE-RELAY//1.html
http://www.allelectronics.com/make-a-store/item/SRLY-2/SOCKET-FOR-AUTOMOTIVE-RELAY//1.html
In-Line Fuse 16 gauge http://www.connectorsupply.com/catalog/automotive-and-marine-mini-blade-fuse-holder-p-82.html
H4 Male & Female http://www.comagination.com/parts.htm
Molex 3 Pin Connectors - .062" Series http://www.frys.com/product/1651418?site=sr:SEARCH:MAIN_RSLT_PG
PIAA Switch, Part # 74034 http://www.spoiledbiker.com/74034.html
Crimping Tool Waldom, Part# W-HT-1921-P
For those who want a simplier version and do not want to create their own, check this out http://www.electricalconnection.com/driving-lights/dl-1watt.htm
I have attached the wiring schematic
Let me know if you have any questions - Attachments
- (67 Kb) Downloaded 20 times
| Subject: Re: Hi Beam Break Out Connector Sat Dec 04, 2010 9:48 pm | |
| Giving this thread a boost as I added a wiring schematic and some other info. |
| Subject: Wiring Diagram Sun Dec 05, 2010 1:05 pm | |
| Hey Erick
Thanks for sharing your excellent wiring diagram update and your parts source links for your Break Out Connector circuit.
It's also good to know that the whole thing is available pre-assembled from one source too ---as quite a few here on the forum don't have access to the tools to DIY.
| Subject: Re: Hi Beam Break Out Connector Mon Dec 06, 2010 4:28 pm | |
| I am making a correction on the design.
If you plan on using a switch, I would highly recommend using a relay with a diode. This will prevent reverse voltage spikes from the coil to your switch.
Here is the one I purchased.
| Subject: Re: Hi Beam Break Out Connector Mon Feb 14, 2011 4:09 pm | |
| Is anyone interested in this connector?
Let me know as I no longer need it.
I will be willing to sell at cost of parts plus shipping.
