| Blueypeas Intro and a problem | |
Blueyepeas Scooter Rider
Number of posts : 5 Location : Kent Points : 2012 Registration date : 2019-05-28
| Subject: Blueypeas Intro and a problem Tue May 28, 2019 3:31 pm | |
| Hi ..lm completely new to this kind of thing , not even sure lm putting this in the right place ! I'm new to owning a silverwing scooter always had the Honda vfr but thought with getting older and the constant average speed cameras in Kent try something new ! I was wondering if any one could help me , l have owned this silverwing for a few months , tonight Conway home the fi light came on and the bike just shut down , nothing works , no lights , ignition except for a buzzing noise from one of the regulator behind the side panel when l turn the ignition on .if anyone could shed some light on this would be greatly appreciated. Have checked all the fuses all seem good |
Number of posts : 3838 Age : 75 Location : Seaham, Co Durham, UK Points : 9709 Registration date : 2009-06-29
| Subject: Re: Blueypeas Intro and a problem Tue May 28, 2019 4:20 pm | |
| Hello and welome!
Is that Kent, UK? |
| Subject: Re: Blueypeas Intro and a problem Tue May 28, 2019 4:25 pm | |
| Hi ..thankyou ! Yes it is the UK |
| Subject: Re: Blueypeas Intro and a problem Tue May 28, 2019 4:28 pm | |
| Good!
I've had some lovely rides in Kent with the X9 Owners Club.
I can't help with your problem but someone will be along soon. |
| Subject: Re: Blueypeas Intro and a problem Tue May 28, 2019 4:35 pm | |
| Yes , there are some nice rides around here , l mainly just commute these days unfortunately! Hopefully l will get an answer because lm stumped when it comes to electrics ! |
Number of posts : 4415 Age : 81 Location : damn near Philadelphia, PA Points : 10747 Registration date : 2009-06-12
| Subject: Re: Blueypeas Intro and a problem Tue May 28, 2019 4:39 pm | |
| Hello and welcome to the forum. Sorry to near about your problem.
It might help to know the year and miles on your Silverwing. However by your description you're going to need access to the Factory Service Manual (FSM) to wade thru the many possibilities of problem and the PGI-FM failure codes.
That said, there are a couple of notes in Chapter 5 (5-2) which you might find of interest. The first says; A faulty PGI-FM system is often related to poorly connected or corroded connectors. Another note says; The system is provided with a fail-safe function to secure minimum running capability even when there is trouble in the system. Yet another note says; that when an abnormality is detected in the injectors, and/or Crankshaft Position sensor and Camshaft Position sensor the fail safe function stops the engine to avoid engine damage.
Dunno what else to tell you, but you should start by removing that left side body panel to check the ECM wire harness connections and see if you can figure out where that buzzing noise is coming from.
Please let us know hiw you get on with this problem. We all benefit from shared information.
GoonerKev Silver Wing Rider
Number of posts : 409 Age : 70 Location : Reigate, Surrey, UK Points : 2517 Registration date : 2019-04-09
| Subject: Re: Blueypeas Intro and a problem Tue May 28, 2019 4:55 pm | |
| Blueyepeas Welcome mate, hopefully something will turn up for you |
| Subject: Re: Blueypeas Intro and a problem Tue May 28, 2019 5:26 pm | |
| Hi Tim The bike only has 9000 and it's an 2007 , l did remove the left panel had a good look around all seems ok , the buzzing is coming from one of the black regulators , complete mystery! |
The Bern Silver Wing Expert
Number of posts : 897 Location : Telford, UK Points : 4633 Registration date : 2014-11-20
| Subject: Re: Blueypeas Intro and a problem Tue May 28, 2019 6:00 pm | |
| Hello & welcome bud.
Kentish man
Or
Man of Kent
You say you have checked ALL the fuses, did you find the main 30 amp one, that's behind the left hand body panel that's located near the battery box ? |
| Subject: Re: Blueypeas Intro and a problem Tue May 28, 2019 6:09 pm | |
| Hi !.. l think more of a kentish man ha Yes , l did eventually find it , looks all good even the spare in the bottom of the case is still there , all looks newish under there |
| Subject: Re: Blueypeas Intro and a problem Wed May 29, 2019 6:44 am | |
| Ah good, us Kentish men are the best of the bunch :Happy Holiday: Ok, the next thing to do is turn the ignition on & with a screw driver held to your ear (by the handle) touch the tip on each relay in turn, identify & remove the one that is making the 'arcing' sound & substitute it with another off the bike that has the same number on the case or prise the cover off the offending relay & clean the contacts with fine emery/carborundum paper. |
| Subject: Re: Blueypeas Intro and a problem Wed May 29, 2019 6:49 am | |
| Also try a gentle tap all around the relay. As Bern said , contacts may have pitted and stuck. |
Delray Touring Scooter Rider
Number of posts : 399 Age : 71 Location : Delray Beach FL Points : 2821 Registration date : 2018-07-07
| Subject: Re: Blueypeas Intro and a problem Wed May 29, 2019 7:36 am | |
| "Kentish man
Or
Man of Kent
This sent me a-Googling. Not only is there a lot of info available, but the origins of the discrimination can be traced back to the 5th Century.
Which is kind of mind-blowing to an American. At a relatively youthful 243, we are still a bounding puppy among nations.
I remember eating in a 300-year old restaurant near Stratford-upon-Avon and I (at 6'1") had to duck down to pass through each doorway, because normal people were much shorter then. |
| Subject: Re: Blueypeas Intro and a problem Fri May 31, 2019 1:40 am | |
