| | Front wheel off | |
GoonerKev Silver Wing Rider
![GoonerKev](https://2img.net/u/3413/63/00/33/avatars/5164-56.jpg)
Number of posts : 409 Age : 70 Location : Reigate, Surrey, UK Points : 2440 Registration date : 2019-04-09
![Front wheel off Empty](https://2img.net/i/empty.gif) | Subject: Front wheel off Wed Jun 12, 2019 2:24 pm | |
| A friend of mine has just bought a Swing, we swapped bikes last night on a ride as he said it had a slight wobble on front wheel, sure enough when I rode it I had a very slight wobble between 35 & 40 mph which suggests to me it needs balancing as there are no weights on front wheel at all, shook wheel and bearings seem ok, how would you suggest getting front up in air, bottle or scissor jack with wood on under bike, but not sure of solid part without taking under-skirting off, thank for your help.
Kev |
| ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | oldwingguy Silver Wing Guru
![Front wheel off Empty](https://2img.net/i/empty.gif) | Subject: Re: Front wheel off Wed Jun 12, 2019 2:54 pm | |
| Up on center stand, small jack with a board under the engine lift to get wheel off ground. Somewhere in the search section you will find more., yep in the maintenance section, jacking up s'wing ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) |
| ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | GoonerKev Silver Wing Rider
![Front wheel off Empty](https://2img.net/i/empty.gif) | Subject: Re: Front wheel off Wed Jun 12, 2019 3:01 pm | |
| Many thanks Oldwingguy ![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif) Brilliant & found it and all good, appreciate that |
| ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | The Bern Silver Wing Expert
![The Bern](https://2img.net/u/3413/63/00/33/avatars/3758-23.gif)
Number of posts : 897 Location : Telford, UK Points : 4556 Registration date : 2014-11-20
![Front wheel off Empty](https://2img.net/i/empty.gif) | Subject: Re: Front wheel off Wed Jun 12, 2019 3:22 pm | |
| Other than out of balance, tyre wear (particularly 'scolloping/cupping') can generate wheel wobble
![Front wheel off Empty](https://2img.net/i/empty.gif) | Subject: Re: Front wheel off Wed Jun 12, 2019 3:58 pm | |
| Bern "'scolloping/cupping'" new to me mate !!, so do you mean some sort of tyre wear then. |
![Front wheel off Empty](https://2img.net/i/empty.gif) | Subject: Re: Front wheel off Wed Jun 12, 2019 4:39 pm | |
| Yep, uneven wear of the tread 'blocks' radially & diametrically
google it & look at the images bud |
![Front wheel off Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/s/t/12/97/68/i_down_arrow.png) | | | Front wheel off | |
Similar topics | ![+](https://2img.net/s/t/12/97/68/i_tabs_more.png) |
