Secret to getting the front wheel off?  I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Secret to getting the front wheel off?  I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Secret to getting the front wheel off?  I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Secret to getting the front wheel off?  I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Secret to getting the front wheel off?  I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Secret to getting the front wheel off?  I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Secret to getting the front wheel off?  I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Secret to getting the front wheel off?  I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Secret to getting the front wheel off?  I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Secret to getting the front wheel off?  I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
3 posters
moosedaisy
Number of posts : 84
Registration date : 2012-05-22
Secret to getting the front wheel off?  Empty
PostSubject: Secret to getting the front wheel off?    Secret to getting the front wheel off?  I_icon_minitimeMon Jun 11, 2012 7:53 pm
I've got an 07 silverwing and today I attempted to remove the front wheel so I can replace the tires. The instructions I found on this site said loosen the 8mm pinch bolts on either side then loosen the 22mm bolt and then pull the bolt out from the right side. I tried loosening the 22m bolt but at first it was really hard. I got my breaker bar out and was able to get the bolt to spin but it wouldn't get any looser. The instuction say to then pull the bolt out from the right side. I can't figure out how do do this. The bolt is not getting any looser no matter how much I turn in. I'll attach some pics of the left and right side so you guys can see if anything doesn't look right.
Secret to getting the front wheel off?  Rightside
Secret to getting the front wheel off?  Leftside-1
matthew
matthew
Number of posts : 361
PostSubject: Re: Secret to getting the front wheel off?    Secret to getting the front wheel off?  I_icon_minitimeMon Jun 11, 2012 8:03 pm
On my '04, the axle comes out from the left side as you're working on the bike. It's the right side if you were sitting on the bike. You might try sticking a small metal something - screw driver or the like - thru the holes on the left side of the axle (as you're working on it), and hold it steady while turning the nut on the opposite side counter clockwise. Maybe that will provide the means to hold the axle itself still for nut removal. If this works, you should be able to relatively easily finesse the axle out. If it does start to come out, be careful to hold onto the wheel a bit so it doesn't just fall down when the axle is removed all the way.
moosedaisy
PostSubject: Re: Secret to getting the front wheel off?    Secret to getting the front wheel off?  I_icon_minitimeMon Jun 11, 2012 9:02 pm
Thanks. I ended up tapping it out with a rubber hammer from the right side if you sitting on the bike. Once I put the new rubber on I'll clean it up and apply some grease. Hopefully this will make the process easier next time.
Number of posts : 3837
PostSubject: Re: Secret to getting the front wheel off?    Secret to getting the front wheel off?  I_icon_minitimeTue Jun 12, 2012 5:31 am
Many people swear by Copaslip for application in such situations - ordinary grease sometimes dries out and sticks the parts together, making the situation worse.
» Front wheel off
» Something funky going on with the front wheel
» Front Wheel Bearings
» Unsteady front wheel
» Front wheel seems a bit heavy
