Strange Leak ! I_icon_minitimeby xwelder Today at 12:31 pm
Strange Leak ! I_icon_minitimeby GHM-PM Today at 8:06 am
Strange Leak ! I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Strange Leak ! I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Strange Leak ! I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Strange Leak ! I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Strange Leak ! I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Strange Leak ! I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Strange Leak ! I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Strange Leak ! I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Strange Leak !
micbusathens
GoonerKev
GoonerKev
GoonerKev
Number of posts : 409
Registration date : 2019-04-09
Strange Leak ! Empty
PostSubject: Strange Leak !   Strange Leak ! I_icon_minitimeFri Jun 21, 2019 3:46 pm
Here's a strange one.
Have not rode bike since yesterday, went to get on it tonight and noticed some splashes of some substance, it feels oily on the fingers but no odour at all. Wrong side for leak on brake cylinder (there's no sign of leaks on it at all), nothing around the Final Drive Top-Up area or Drain bolt area, this has got me stumped Shocked Embarassed Shocked
Kev
Strange Leak ! Img_2049
Strange Leak ! Img_2048
Strange Leak ! Img_2047
micbusathens
micbusathens
Number of posts : 199
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeFri Jun 21, 2019 4:21 pm
Clean it and see if continues.Looks like you steped on something🤔Dog pee maybe.
GoonerKev
GoonerKev
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeFri Jun 21, 2019 4:33 pm
Not dog pee as it's oily, looked all underneath as I have side panel off as well and cant see where it's come from. Shocks are clean and dry, Brake hoses are dry also !!
Number of posts : 1013
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeFri Jun 21, 2019 11:40 pm
There is a crankcase breather hose that exits out of the left side next to the center stand. The hose is clear and should be plugged. It is purposely clear so that you can see if deposits are present and can be cleaned by removing the plug. Maybe the plug is missing.
There is another hose that exits out the lower right side plastic through a hole. This hose is black rubber hose for the coolant overflow. The hose is not plugged. Maybe someone didn't put back the hose through the plastic and coolant overflow is leaking into the frame of your bike.
Could be antifreeze from the overflow. Antifreeze has some oiling properties. Check the reserve tank level when engine has warmed up.
GoonerKev
GoonerKev
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeSat Jun 22, 2019 4:16 am
Easy
Many thanks for that information, those are the only two thing's I did not check.
Update:
Checked both hoses and are in situ and left hand one still has bung in, have cleaned the area's contaminated and will take out for a ride later and re check............................
The mystery goes on !!! Sad
Number of posts : 1935
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeSat Jun 22, 2019 7:48 am
Strange indeed, no radiating pattern looks more like it was splashed on somehow. Follow the " oil " forward to see where it stops.
GoonerKev
GoonerKev
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeSat Jun 22, 2019 8:28 am
Oldwingguy
Indeed strange, only goes as far as the end of the Belt/Final drive cover, no further than that. I am not so sure if I rode over some sort of oil on the ride back as it has the pattern of flicking up from tyre to the surrounding area !!!
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeSat Jun 22, 2019 8:49 am
That or you have someone messing with you, we did that a time or 2 with our GW friends, putting just a wee bit of used oil under the bike.
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeSat Jun 22, 2019 9:11 am
Yes, perhaps a visit from the treacle fariy.
GoonerKev
GoonerKev
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeSat Jun 22, 2019 9:22 am
I WILL FIND THEM, AND I WILL...............
Just had a nice little 10 mile ride (longer than the other day when I rode it and discovered the mess), used loads of breaks, slow, normal & fast speeds, engine up to temp before setting off. No mess at all, so it looks like someone is trying to Pi$$ me off or the Treacle fairy wants some attention Evil or Very Mad Exclamation
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeSat Jun 22, 2019 1:17 pm
GoonerKev
Ride safe and with aloha! Check where you stopped and was away from your bike. Someone may have it in for you.
AldusFran
Number of posts : 210
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeSun Jun 23, 2019 7:14 pm
Goonerkev, I had the same thing happen on two of my previous bikes ; on left side also. After much looking at bike I figured nothing but road slop.
AldusFran
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeSun Jun 23, 2019 7:24 pm
Oh I forgot to mention-hydraulic fluid spill from garbage trucks,tractors and dumpsters. It can be hard to notice while riding especially on gravely roads
GoonerKev
GoonerKev
PostSubject: Re: Strange Leak !   Strange Leak ! I_icon_minitimeMon Jun 24, 2019 2:41 am
AldusFran
Thanks for that info, I am now 90% sure it was picked up on the road somewhere !
Strange Leak !
» something strange
» Strange sound or not?
» Strange running noise
» Strange Noise
» Strange noise at 5 mph!
