» Rear wheel valve stem
Teeth Marks On Front Pulley I_icon_minitimeby MikeO Today at 6:19 pm
Teeth Marks On Front Pulley I_icon_minitimeby COMick Today at 6:13 pm
Teeth Marks On Front Pulley I_icon_minitimeby xwelder Today at 12:31 pm
Teeth Marks On Front Pulley I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Teeth Marks On Front Pulley I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Teeth Marks On Front Pulley I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Teeth Marks On Front Pulley I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Teeth Marks On Front Pulley I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Teeth Marks On Front Pulley I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Teeth Marks On Front Pulley I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Number of posts : 1607
Teeth Marks On Front Pulley Empty
PostSubject: Teeth Marks On Front Pulley   Teeth Marks On Front Pulley I_icon_minitimeMon Jan 13, 2020 3:02 pm
What is it with my SW?
Whilst reassembling everything after cleaning up my clutch assembly, I noticed these marks on both the front Inner and Outer pulley halves:
Teeth Marks On Front Pulley Front_11
Teeth Marks On Front Pulley Front_12
They won't budge even after very gentle 'wet and dry' microfine rubbing.
What the ****? Could it be connected with grease and glazing I found on the clutch pads?
Number of posts : 1384
PostSubject: Re: Teeth Marks On Front Pulley   Teeth Marks On Front Pulley I_icon_minitimeMon Jan 13, 2020 8:16 pm
Marks are from the belt.  Any grease or oil on belt. ?  A little brake clean and a rag will remove it.
I wouldn't worry about it  takes a bit of oil on belt before it starts to slip.  I once over filled rear diff. and belt was soaked in oil but only slipped at full throttle otherwise I never would have felt a problem.
The inner pulley needs the slightest amount of grease on collar. Just a little on seal wipe off excess on belt side.
Lenny
Number of posts : 36
Registration date : 2019-09-08
PostSubject: Re: Teeth Marks On Front Pulley   Teeth Marks On Front Pulley I_icon_minitimeTue Jan 14, 2020 3:59 am
It could be a message in Hieroglyphics left by ancient Egyptians, the Silverwing was around then wasn't it. Smile
Number of posts : 1935
PostSubject: Re: Teeth Marks On Front Pulley   Teeth Marks On Front Pulley I_icon_minitimeTue Jan 14, 2020 7:14 am
???????? heat marks from OEM welding on the other side ? Marks evenly spaced and look a lot alike.
PostSubject: Re: Teeth Marks On Front Pulley   Teeth Marks On Front Pulley I_icon_minitimeTue Jan 14, 2020 1:49 pm
Thanks for your comments all. Grease on the belt makes sense since my habit of overgreasing the rear pulley shaft which, of course, is not necessary and I've broke the habit.
Well, I've given it all a good clean but had never thought of putting a speck of grease on the inner pulley collar. I've always kept that front pulley assembly completely dry because of the risk of contamination but the suggestion makes sense.
BTW Lenny, A mummy covered in chocolate and nuts has just been discovered in Egypt!!! Archaeologists believe it may be a 'Pharaoh Roche'. My Silverwing was definitely around back then!
Anyhow, all seems well thumbs up
abdullahb
Number of posts : 52
Registration date : 2020-01-12
PostSubject: Re: Teeth Marks On Front Pulley   Teeth Marks On Front Pulley I_icon_minitimeThu Jan 16, 2020 1:43 pm
no biggie man!
PostSubject: Re: Teeth Marks On Front Pulley   Teeth Marks On Front Pulley I_icon_minitimeSat Jan 18, 2020 3:21 pm
Just thought I would add...I gave the pulleys and the belt a good clean up today. The belt was quite contaminated. Glad I took a look.
Hope this stops the squealing Cool
Sepp
Number of posts : 126
Registration date : 2019-10-09
PostSubject: Re: Teeth Marks On Front Pulley   Teeth Marks On Front Pulley I_icon_minitimeSun Jan 19, 2020 5:55 pm
well forget grease lightning
https://youtu.be/wK63eUyk-iM chickendance chickendance chickendance
the best things against a squealer are concrete boots Laughing Laughing Laughing Laughing Laughing Laughing
https://hosiwi.blogspot.com/
» Final drive front pulley oil leak
» Pull behind Trailer
» Is it me or my side stand and center stand making marks or d
» Does honda silver wing has dual ABS (front and back) or only front ?
» Dr Pulley sliding weights vs rolling weights
