| Lost Only Key | |
+4Mech 1 twa Cosmic_Jumper GHM-PM sc00ter 8 posters |
awaldman91 Scooter Rider
Number of posts : 9 Location : NJ Points : 1808 Registration date : 2019-12-17
| Subject: Lost Only Key Mon Mar 02, 2020 10:12 pm | |
| Hello All,
Long time reader, 1st time poster. Inherited an 06 fsc600 from my dad with 5000 miles and ride all the time. Yesterday I lost my only key in the park. My dad was the second owner so we don't have the original key code plate, and it doesn't have HISS, so I have read that I can possibly find the key code on the ignition cylinder somewhere? Does anyone know exactly where? Also how many digits and if its alphanumeric generally? I am trying to use a boroscope to see if I can find it fishing around without having to remove the lock. If I do need to remove the lock (I am relatively mechanically inclined), it looks like I need to remove the handlebars? Is that true? I started but thought there may be an easier way to do this. Any help is greatly appreciated, I am missing some nice early spring weather! Thanks! |
sc00ter Super Scooter Rider
Number of posts : 232 Location : Norfolk, VA Points : 2569 Registration date : 2018-07-16
| Subject: Re: Lost Only Key Tue Mar 03, 2020 12:31 am | |
| I had a stripped of most panels Silverwing and I went by the guys house I gave it to today and looked. No codes on the ignition. Prior owner had it hot-wired because the key got super stuck and it broke off in the ignition switch. He ordered a used ignition assembly off ebay and that one was also worn out. So be careful buying used because it might be worn out already. Did you look in the owners manual and see if the prior owner wrote it in there? |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 7:41 am | |
| Not sure this will help but perhaps your dealer can find it with the VIN number. That has worked for me with cars. Call your nearest Honda dealer and ask for service. Worth a try. Good luck. |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 8:01 am | |
| Unfortunately I did not buy it new, my dad was the second owner. There aren't any stickers for a dealer anywhere on the bike and I don't have the original owners manual. I know where the original owner lived and Im trying to narrow down dealers. It would have had to been bought at a honda powersports dealer right? Not like a regular car dealer? |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 8:23 am | |
| There is a key code number on the lock. IIRC it’s on the lock assembly face sandwiched to the steering stem. That’s by design so that nefarious bastards can’t find it. So you’ll need to remove the entire front of the scoot (from the gas cap forward) to access that number. If it’s any consolation, you’d have to remove all that stuff anyway if you were to replace that lock assembly. As long as you’ve got access to the lock assembly you can take it to a good locksmith and have a new key made. I kinda doubt that Honda can provide you with a precut key for your specific lock cylinder anyway. A key blank, yes. A precut key, no. Tip. When you remove all those panels you’re sure to discover missing and broken tabs and cracks. Best to get some Plast-Aid * on hand so that you can fix those things at the time —rather than wait until that stuff to arrive. Here’s a link to a help you get started removing the front end: https://www.silverwing600.com/t11101-remove-front-fairing-how-to-video?highlight=Remove+frontTim * https://www.youtube.com/watch?v=1YGzjWeK-nY |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 9:08 am | |
| From what I understand, the dealer the scoot was bought from should have the key code on file, but you need to find that dealer. Thanks for the helpful information though. I actually bought a aervice manual online because I have almost come to terms that Ill need to do this lol. I just hate removing body parts because things always break and don't go back right, then you get annoying vibrations, etc. |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 10:53 am | |
| Hmm... Maybe you could plug in the VIN# to one of those Car Fax-type sites and get a record of previous owners and/or the original dealer. If you can locate the original owner then you might check with the closest Honda dealer. |
rustysdream Maxi-Scooter Rider
Number of posts : 114 Location : Ontario, Canada Points : 1850 Registration date : 2020-02-26
| Subject: Re: Lost Only Key Tue Mar 03, 2020 2:43 pm | |
| I guess, I'm in the same boat. I have only one key for the bike. It works fine but I don't have a key code plate. Thank you for your help, Tim. |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 4:34 pm | |
| - rustysdream wrote:
- I guess, I'm in the same boat.
I have only one key for the bike. It works fine but I don't have a key code plate. Then you should probably get a 2nd key made now before you’re in the same predicament as Mr Waldman —who’ll, no doubt, be having two keys made as soon as he can extricate his lock assembly. |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 7:31 pm | |
| Is the key code on the seat lock cylinder also ?? But you still have to find a way to open seat. Seat lock might use only some of tumblers NOT all for the ignition and cutting a key for that still won't work. ??
Original dearer might have the code if they retained all the paper work. Honda auto dealers can access the key codes just from the VIN # Bike dealers I'm not sure. They won't just give it to you over the phone though. They need proof of ownership and some ID.. Larger dealers should be able to cut a key from 8 digit key code. A bike dealer should be able to trace original dealer from Honda VIN inquiry on bike and the key code. I can do it for cars but I have a log in to Honda auto network.
| Subject: Re: Lost Only Key Tue Mar 03, 2020 8:23 pm | |
| I already ordered some key blanks. Definitely will be making multiple spares after I square this away!
Is the key code on the lock cylinder of the seat? Can anyone confirm that? My seat is actually still unlocked. I wouldn't want to pull it out if I don't need to, but I have read mixed things about the lock code being there or not. I am sure it is the original lock, everything opened with the original key. I was hoping today that the key may have been turned in to the police or parks department, but still no luck. At this point I have just about given up hope on getting my key back and will start calling dealers tomorrow. |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 8:43 pm | |
| Thank you for your comments. I'll have a couple of spare keys cut before the riding season but I'm still waiting for the dealer to get the second key from the previous owner. Also, I will ask my daughter to see if she still has a connection. She used to work for a Honda dealership. |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 8:48 pm | |
| Thanks. I actually just pulled the seat lock, there are some markings, but not sure if it is the key code. There are 6 characters/numbers, but they are 3 over three (i.e ABC/123). From what I can roughly see on pictures from ebay listings on the lock cylinder it is one line (can't tell if it is numeric or alphanumeric). |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 9:08 pm | |
| Do they not have a gun looking device that they insert into a lock to replicate the key, once the design is determined make a new key? |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 9:43 pm | |
| I just checked. There is a code on the fuel cap cylinder. It's 1 digit and 2 letters. Would that be the same for the other locks? |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 10:09 pm | |
| The seat lock is pretty easy to pull, 4 screws on the left rear fairing and a spring clip on the lock. You should check and see if that matches the gas cap then that may be it. |
| Subject: Re: Lost Only Key Tue Mar 03, 2020 11:54 pm | |
| Subject: Re: Lost Only Key Thu Mar 05, 2020 9:25 am | |
| It's a one key fits all deal, why not? |
| Subject: Re: Lost Only Key Thu Mar 05, 2020 10:02 am | |
| It's not a Silver Wing, but the key code seems to be at the same place.
https://www.youtube.com/watch?v=hN5WDXGOqio |
| Subject: Re: Lost Only Key Thu Mar 05, 2020 5:19 pm | |
| Gas cap never thought of that. I unlocked mine no key needed anymore one less thing to worry about.
It's been covered here before it's easy to do.
My key tag that came with SW is an 8 digit # . |
| Subject: Re: Lost Only Key Thu Mar 05, 2020 11:55 pm | |
| Well I pulled the ignition cylinder, key code was stamped on the back, so I guess it is only on the ignition. Took me about 45 min to pull it, not bad. No broken plastics. I found a guy on ebay that will cut to the key code, but can't seem to find a locksmith around here that will. Is there a way to convert the three digit key code to a numerical code? |
| Subject: Re: Lost Only Key Mon Mar 09, 2020 9:15 pm | |
| So just in case anyone ever has this issue in the future, and wants solid information like I did, here's what worked (I know some already said this stuff, but here's confirmation):
The key code is printed on the back side of the ignition cylinder only. It is printed on the side that is up against the steering column and unable to be read with a boroscope. I checked the seat lock and gas cap and neither had that number. It starts with a letter followed by 2 numbers and it is the last 3 digits of a 6 digit alphanumeric string. No one in my area even makes motorcycle keys really, but there are guys on ebay that for 12-15 usd you send them your year make model and key code and they will cut the key. The easiest way to get the code was take the air duct, windshield, lower and upper front covers off, then the handlebars, then the two pinch bolts on the steering column off. I pulled up the lock cylinder, took a picture of the code, then put it right back, torqued the pinch bolts, then the handlebars then reverse order the rest. The service manual says to take off all the stuff off the handlebars, but there's no point because you can just work around it all. Took me about an hour each way and all i broke were a few plastic trim clips. I also have a cordless ratchet and cordless screwdriver with some attachments that saved a boatload of time. Especially getting to the pinch bolts on the steering column, if I only had a mechanical ratchet that would have added significant time right there Needless to say, it was not fun, but I was able to get in an hour riding on this 72 degree day in NJ. Thanks y'all for your help. |
| Subject: Re: Lost Only Key Mon Mar 09, 2020 9:46 pm | |
| Wow! That's a lot of work to get the key code but great to hear that you were able to ride too. |
| Subject: Re: Lost Only Key Mon Mar 09, 2020 10:17 pm | |
| Unless you bought the bike new and know where it was bought from (even still I called a few dealers and they said they don't cut keys from code, only could sell me a new ignition cylind3r and locks), or have the key code plate, this is the cheapest and least time consuming option. |
| Subject: Re: Lost Only Key Tue Mar 10, 2020 8:24 am | |
| Glad to see you got it sorted out. When I bought my 05 one of the first thing I did was have 3 extra made, it too only came with one. This incident made me glad I did as at $ 2.50 a key it's cheap insurance. |
| Subject: Re: Lost Only Key Tue Mar 10, 2020 10:41 am | |
| As long as we are discussing keys, here are key blank numbers for replacement keys:
Keyport: HD109 Ilco: 265 Ilco EZ Line: HD109 JMA: Hond-33
Regrettably there seems to be no replacement information for HISS keys. |
| Subject: Re: Lost Only Key Tue Mar 10, 2020 11:24 am | |
| Honda HISS keys are used on the British and European FJS Silver Wings, and you may or may not be able to use the code stamped on the metal strip fitted the keyrings of what should be your spare set of keys. The info about the HISS is no doubt available in the FSM for the Honda FJS 600 Silver Wing, they are sometimes on sale on eBay. Usually these manuals are usually in poor condition and sellers are wanting top dollar.
That's why British owners who aren't too mean to buy their own FSM usually buy a pristine condition one off the internet for the FSC version, which of course doesn't have a section on HISS. |
| Lost Only Key | |
