Interesting on greasing related to tire change I_icon_minitimeby sonuvabug Today at 4:19 pm
Interesting on greasing related to tire change I_icon_minitimeby sonuvabug Today at 4:17 pm
Interesting on greasing related to tire change I_icon_minitimeby sonuvabug Today at 4:06 pm
Interesting on greasing related to tire change I_icon_minitimeby JohnyC Yesterday at 10:04 am
Interesting on greasing related to tire change I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Interesting on greasing related to tire change I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Interesting on greasing related to tire change I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Interesting on greasing related to tire change I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Interesting on greasing related to tire change I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Interesting on greasing related to tire change I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Number of posts : 1935
Interesting on greasing related to tire change Empty
PostSubject: Interesting on greasing related to tire change   Interesting on greasing related to tire change I_icon_minitimeSun Jun 21, 2020 12:15 pm
The front wheel axle calls for some grease but the rear doesn't mention Moly 60 or any grease on the spline, only in the grove on the axle shaft, this is by the service manual. Any of the DIY crowd do it any different, me doesn't make much sense if it's not a moving part to use grease.
bikerboy
Number of posts : 405
PostSubject: Interesting on greasing related to tyre change    Interesting on greasing related to tire change I_icon_minitimeSun Jun 21, 2020 12:59 pm
I put a smear of Rocol ASP on the splines when I had a SWing, the same as I did on my Deauville and the ST1100 when I had them.  A smear can't do any harm and it may be a good preventative measure in the long run.
Number of posts : 3314
PostSubject: Re: Interesting on greasing related to tire change   Interesting on greasing related to tire change I_icon_minitimeSun Jun 21, 2020 1:26 pm
I used a grease smear on rear splines----90,000 plus miles=no trouble
Ken j
Ken j
Number of posts : 46
Registration date : 2020-06-16
PostSubject: Re: Interesting on greasing related to tire change   Interesting on greasing related to tire change I_icon_minitimeSun Jun 28, 2020 10:03 pm
I just did my first rear tire change on my Swing and I found grease on the rear spline from the old owner's maintenance. Since it was the first time I was in there, I cleaned the area getting all the dirt and road gunk out. I did use some moly on the splines of the axle shaft when installing the wheel back on. Sure I understand that it is a non moving part but my thinking is that if I ever need to pull the wheel again (and I will on the next tire change), it will help in removing it. Non moving parts such as splines and mating grooves can rust together making it more difficult to separate.
PostSubject: Re: Interesting on greasing related to tire change   Interesting on greasing related to tire change I_icon_minitimeMon Jun 29, 2020 8:44 am
I too did a bit of Moly 60 on that spline but as the Service Manual shows the grease goes in that grove on the shaft. A little is all, no need to slather it on.
Number of posts : 933
PostSubject: Re: Interesting on greasing related to tire change   Interesting on greasing related to tire change I_icon_minitimeMon Jun 29, 2020 10:18 am
... snipped ... I used a grease smear on rear splines--no trouble
^^^ +1 ^^^
» Did I change last scooter tire today??
» Rear wheel removal !!!
» front tire change
» Trike Tire Change ?
» How do I change a rear tire, easily?
