Latest topics | » Easy gps connection to brake switch by gettyuptogo Today at 5:14 am
» First impressions of the silver wing by RedRaider Yesterday at 3:04 am
» Throttle Body Jiggle Valve by Terry Smith Sun Sep 15, 2024 8:24 pm
» 2025 Silverwing 600! by Meldrew Sun Sep 15, 2024 9:22 am
» From Dayton, Ohio by JohnyC Sat Sep 14, 2024 5:05 am
» Hello from Fort Worth,Tx by RedRaider Fri Sep 13, 2024 7:59 am
» Drive faces by zrx212 Sun Sep 08, 2024 1:57 pm
» Mechanics in Los Angeles? by Whiteclay Sun Sep 08, 2024 6:45 am
» V Belt Light by zrx212 Sun Sep 08, 2024 4:39 am
» Introducing ME by GHM-PM Sat Sep 07, 2024 11:21 pm
| | Now I'm confused. Which one is the clutch? | |
| Subject: Now I'm confused. Which one is the clutch? Tue Feb 09, 2010 4:14 pm | |
| https://www.youtube.com/watch?v=-tdVY6Kone4
I know how the variator works, but it looks like it has TWO variators.
I was wondering what happens to the "slack" when the variator changes pitch, but now I can see that both the front and the rear gadgets change proportionally.
Here's my brain's attempt to understand:
1. The front gadget is the clutch. The fat coil spring tends to keep the cones squeezed together, and that's what takes up the slack of the belt.
2. The rear gadget is the variator.
3. The variator is what actually changes the "gearing." The front pulley expands or narrows as the force of the variator "pulling" on the belt forces it to do so over the objection of the coil spring. So the front gadget is just passively reacting to what the variator does.
Right?
Please tell me I'm right. |
| | | Guest Guest
| Subject: Re: Now I'm confused. Which one is the clutch? Tue Feb 09, 2010 4:18 pm | |
| Oops. Clutch rear, variator front. |
| | | Guest Guest
| Subject: Re: Now I'm confused. Which one is the clutch? Tue Feb 09, 2010 4:31 pm | |
| By the way: What's the weight of the OEM rollers? |
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10681 Registration date : 2009-06-13
| Subject: Re: Now I'm confused. Which one is the clutch? Tue Feb 09, 2010 4:44 pm | |
| 1) The 'front gadget' would be the object on the left. It's the Variator. It expands or narrows relative to the engine rpm's and the centrifugal force on the variator roller weights, or slider weights. 2) the 'rear gadget' is the Driven Pulley assy. Hidden behind the Driven Pulley is the clutch itself. The clutch shoes expand as the Driven Pulley's rpm increases. The shoes expand to contact the Clutch Bell (Honda calls it the Clutch Outer) which is directly connected to the rear wheel via the final reduction gears. 3) The action of the Variator Pulley and Driven Pulley expanding and contracting in consort are what changes the gearing. This site might help explain the working of the CVT, but the illustration of the rear pulley/clutch is assbackwards relative to the Silverwing. The Silverwing clutch is attached to the 'back half rear pulley'. http://flexistentialist.org/blog/archives/2003/10/27/cvt-basics-constant-variable-transmissions/ Hope this helps Tim |
| | | tankyuong Silver Wing Rider
Number of posts : 475 Age : 49 Location : Missouri Points : 6231 Registration date : 2009-07-12
| Subject: Re: Now I'm confused. Which one is the clutch? Wed Feb 10, 2010 2:21 am | |
| - mickey wrote:
- By the way: What's the weight of the OEM rollers?
28 grams |
| | | Guest Guest
| Subject: Re: Now I'm confused. Which one is the clutch? Wed Feb 10, 2010 7:18 am | |
- 1) The 'front gadget' would be the object on the left. It's the Variator. It expands or narrows relative to the engine rpm's and the centrifugal force on the variator roller weights, or slider weights.
2) the 'rear gadget' is the Driven Pulley assy. Hidden behind the Driven Pulley is the clutch itself. The clutch shoes expand as the Driven Pulley's rpm increases. The shoes expand to contact the Clutch Bell (Honda calls it the Clutch Outer) which is directly connected to the rear wheel via the final reduction gears. 3) The action of the Variator Pulley and Driven Pulley expanding and contracting in consort are what changes the gearing. This site might help explain the working of the CVT, but the illustration of the rear pulley/clutch is assbackwards relative to the Silverwing. The Silverwing clutch is attached to the 'back half rear pulley'. http://flexistentialist.org/blog/archives/2003/10/27/cvt-basics-constant-variable-transmissions/ Hope this helps Tim And the light bulb goes on! Got it. Thanks. Heavier rollers make the gear ratio lower, like short-shifting a standard transmission. ("Higher" gear, for cruising.) The contra spring makes the gear ratio higher. ("Lower" gear for acceleration.) They have to be in balance. Simple, yet complex. |
Number of posts : 2778 Age : 74 Location : NE Oklahoma Points : 9031 Registration date : 2008-12-29
| Subject: Re: Now I'm confused. Which one is the clutch? Wed Feb 10, 2010 7:33 am | |
| Hi Mickey, Hope this helps: |
| | | Guest Guest
| Subject: Re: Now I'm confused. Which one is the clutch? Wed Mar 10, 2010 4:23 am | |
| hey mickey, That is a video of my bike i made in 08. i'm supprised it gets so many viewers As the others have said, the variator is the larger front one and the clutch is the rear one. As the engine rpm increases the belt in the front increases diameter the the rear spring loaded one is forced to follow. glad you liked my video. Paul |
| | | Guest Guest
| Subject: Re: Now I'm confused. Which one is the clutch? Wed Mar 10, 2010 7:05 am | |
| Having completed the installation of my "yellow springs" and 26 gram rollers I can now say, officially, "I understand." It's an absurdly simple system, really. |
