Rederic, the ABS panels on the Silver Wing are very repairable. I've repaired a few cracked panels, rebuilt missing tabs etc. and with the right basic equipment and correct materials, you can restore older broken ones back to new looking.
That front fairing is pretty expensive so it's worth trying a repair job. Too bad somebody took off the Red Green's duct tape repair ... you wouldn't have had to do anything if it was still on. lol
Go to You Tube and search for Windy Urtnowski -- fairing repair. Dat's where I gots a batch uv muh lernin' from. He does some pretty fine work.
In Canada, Plast-Aid is hard to come by but there is another identical brand that does a great job.
Also, I have some new and gently used panels I've been thinking of selling that you may be interested in. I have the meter panel (the dials sit behind it), the upper dashboard and cubby lids (they are the desired textured black ones from 2007 and on ... not the colour coded ones).
I also have the lower panel that goes directly below the above mentioned dash panel (I think I have a brand new one and an extra used one that has a small crack that needs to be repaired).
If you're interested, I can send you the part numbers or you can send me the parts numbers of the ones you need. Since you can't send a PM yet (you don't have 5 posts), simply post up here if you're interested and we'll connect somehow.
Is that Vancouver B.C. or WA?
