Greetings, I hope what I'm hearing is normal for a varidrive scooter with a dry clutch, I have investigated most things, removed the brake calipers, the swing arm bracket bearing, the clutch cover bearing an all those parts are good.
The scraping noise is still there when I turn the wheel without the engine running, I think only a couple of things could be causing the problem, it is either the clutch shoes touching the clutch drum because of weak springs or worn pins.
The noise reminds me of adjusting drum brakes, so is this normal.
The scooter sounds fine with the engine running and the back wheel rotating.
Regards
Dave
