pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby zrx212 Yesterday at 4:40 pm
pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby Meldrew Yesterday at 4:37 pm
pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Silverwing28681
darrent
darrent
Number of posts : 6
Registration date : 2011-06-12
pushing the bike backwards and slow for first 2 minutes. Empty
PostSubject: pushing the bike backwards and slow for first 2 minutes.   pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeSun Jan 13, 2013 5:48 pm
When I first get onto the bike, I reverse the bike and it is really hard to push it backwards.
Then when I start to move forwards it takes about 2 minutes for the acceleration to get going. so at full revs, it only goes 25 miles per hour.
I have a Silverwing ABS 2007.
I would love some advice.
I was wondering if I needed some new disk brakes.
Thank you.
Darren
Silverwing28681
Silverwing28681
Number of posts : 94
Registration date : 2012-08-16
PostSubject: Re: pushing the bike backwards and slow for first 2 minutes.   pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeSun Jan 13, 2013 5:57 pm
This is a strange problem, Sounds like to me its your variator or clutch,
With " really hard to push it backwards. " and " at full revs, it only goes 25 miles per hour. "
I would look in to that area first I think, Easy to take a quick look and see, Thanks
tarmacburner2
tarmacburner2
Number of posts : 1099
PostSubject: Re: pushing the bike backwards and slow for first 2 minutes.   pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeSun Jan 13, 2013 6:22 pm
What mileage has the scooter done?
What variator have you got installed?
Had a similar problem with mine, J Costa variator installed. Replaced the pins (their equivalent of rollers) and fitted a new belt. That cured the problem on mine.
Cheers,
Number of posts : 2392
PostSubject: Re: pushing the bike backwards and slow for first 2 minutes.   pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeMon Jan 14, 2013 4:19 am
My first thoughts.
Do you use your machine often, (Daily?)
Is the biking wet when you lay it up over night?
If the bike is having long(ish) breaks between riding and the bike is/was damp it may be possible the brakes are binding, (sticking). That would make it difficult to maneuver.
May be worth looking at the parking brake. Is that sticking?
Let us know what you find. Be useful if the snag happens to others.
tarmacburner2
tarmacburner2
PostSubject: Re: pushing the bike backwards and slow for first 2 minutes.   pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeMon Jan 14, 2013 6:36 am
Waspie,
When mine had this symptom is was really noticeable when i did a four day trip to Scotland, every morning exactly the same thing. For the first two miles or so the revs were a lot higher than normal. To get 30 mph i was using 5000 revs. Then it would settle down to normal. I can discount the sticking brakes as far as mine was concerned as at least two mornings I had to push the scoot backwards a few feet to get it into a position where I could set off from. (That is not to say that your suggestion may not be relevant).
Cheers,
Number of posts : 921
PostSubject: Re: pushing the bike backwards and slow for first 2 minutes.   pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeMon Jan 14, 2013 11:54 am
I have the ABS 2007. Sometimes i find the rear brake does bind first thing(it's always kept in a garage),especially this time of year, it usually loosens up in a couple of yards, if it lasted longer that's were i would be looking, as Waspie suggested. Smile
LN
Number of posts : 64
Registration date : 2012-08-18
PostSubject: Re: pushing the bike backwards and slow for first 2 minutes.   pushing the bike backwards and slow for first 2 minutes. I_icon_minitimeMon Jan 14, 2013 11:36 pm
I will do this:
1. Before turning on the bike, on the stand, rotate the back wheel by hand. Does it spin, does it make any noises, grinding noises. where , brakes, inside the case ? Listen where the rear brakes are.
2. Stupid hand brake cost me a lot of money. My Honda dealer thought it was my belt (I changed 1 week earlier) Pull out the hand brake pads. It should take 5 min to do it. Only two screws. I took them all off at 10,000. 80,0000 never needed once.
3. Did you just change the rear brakes? You may have to re-set the pads in the correct position.
4. If you have an impact electric or air tool it takes about 30 min with no special tools to look at the clutch in the back.
Let me know
Smile
» scraping noise when pushing the scoot. engine switched off.
» Fenderectomy on current bike and another future bike Plans
» PROJECT BIKE: Naked Cruiser auto bike
» slow service?
» Help! Cranks slow and won't start. FIXED
