| Additional light wiring | |
rustysdream Maxi-Scooter Rider
Number of posts : 114 Location : Ontario, Canada Points : 1850 Registration date : 2020-02-26
| Subject: Additional light wiring Wed Aug 26, 2020 11:27 am | |
| I have already installed an additional brake light on the Givi top box and now I would like to connect it to the system. What would be the best/easiest point to hook it up? Also, to which wire? Thank you in advance.
| Subject: Re: Additional light wiring Wed Aug 26, 2020 12:09 pm | |
| Best access is to remove the left rear panel —the one with the trunk lock. That will expose the ECM and tail wiring. Unplug the 6-pin connector which feeds the rear lights. The brake light wires are Green Yellow (G/Y) is 12V and Green (G) is ground.
The wiring is only 20 gauge so it is best to use Posi-tap connectors (the red ones).
Here is an eBay link, but you should be able to find these locally in an Auto Parts store: https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1311&_nkw=posi+tap+wire+connectors&_sacat=0 |
| Subject: Re: Additional light wiring Wed Aug 26, 2020 12:16 pm | |
| Thank you so much, Tim. On the way to the garage. :-) |
| Subject: Re: Additional light wiring Wed Aug 26, 2020 4:28 pm | |
| Just finished. It works great. Thanks again, Tim. Luckily, I didn't have the 20 gauge connection at home so I had a valid reason to ride to the neighbour town. Cheers, Frank |
| Subject: Re: Additional light wiring Fri Aug 28, 2020 7:34 am | |
| Next project is, additional tail light and turn signal on the Givi box. I assume, I can use one or two of the remaining wires from the same 6-pin connection. Am I right? Which is the tail light wire and which is the turn signal? Thanks again. |
| Subject: Re: Additional light wiring Fri Aug 28, 2020 7:54 am | |
| Black/Brown - Running Lights Light Blue - Rt Turn Signal Orange - Lt Turn Signal
Green - Ground/Earth Green/Yellow - Brake Lights
More than happy for someone to confirm; I have just copied this from the chart I made when I fitted an Admore Light Bar ten years ago. I had to make a chart as the Admore wire colour-scheme doesn't match the Honda one. |
| Subject: Re: Additional light wiring Fri Aug 28, 2020 8:25 am | |
| Thank you very much, Mike. |
| Subject: Re: Additional light wiring Fri Aug 28, 2020 9:03 am | |
| Pleasure, Frank. Good luck! |
sonuvabug Silver Wing Expert
| Subject: Re: Additional light wiring Sat Aug 29, 2020 12:22 pm | |
| Standard HONDA Wiring Colours
Tail – brown w/white stripe (SWing FSM = Brown/Black) Brake – green w/yellow or red stripe (SWing FSM = Green/Yellow)
Left signal – orange Right signal – light blue
High beam – blue Low beam – white
Ground/earth – solid green |
| Subject: Re: Additional light wiring Sat Aug 29, 2020 6:58 pm | |
| Thank you very much, sonuvabug. |
| Subject: Re: Additional light wiring Sun Aug 30, 2020 8:53 am | |
| - rustysdream wrote:
- Thank you very much, sonuvabug.
You're welcome Frank ... just confirming MikeO's posted information. Good luck with your mods. BTW - Is that your 2009 for sale on Kijiji? |
