Additional DC Generator I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Additional DC Generator I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Additional DC Generator I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Additional DC Generator I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Additional DC Generator I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Additional DC Generator I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Additional DC Generator I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Additional DC Generator I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Additional DC Generator I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Additional DC Generator I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Hammy
eddy
Number of posts : 2778
Additional DC Generator Empty
PostSubject: Additional DC Generator   Additional DC Generator I_icon_minitimeSun Aug 22, 2010 7:48 am
Hi All, Remember...this is just a thought!
Was just thinking of a way to get more power for more lights and accessories on the Silverwing. Now this is just in the idea stage. If anyone wants to develope this ...Head on. Here it is.
Off the rear axle, a small DC generator could be mounted. Not very big...may be 1.5" x 5" dia. and sealed from water and dust.
The rear axle nut is removed and a new axle nut/extender is installed in it's place, rotating the armature inside a fixed stator. Yeah, that would work.
Any one want this....it's yours. Have fun!
Of course, you would only be generating DC volage when going down the road.
eddy
Number of posts : 187
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeSun Aug 22, 2010 8:29 am
Hello Dennis,
Is there a problem with the capacity of the DC generator?
Feeding what items?
Your solution seems to me complex.
http://edho@operamail.com
Hammy
Hammy
Number of posts : 362
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeSun Aug 22, 2010 8:54 am
Hey, Dennis, that's a great idea. Anything that can boost the capacity would be great. Eddy, items that draw a lot include heated clothing, auxiliary lights, electronics. A full heated suit (just pants, jacket and gloves) can knock out close to 300 watts by itself. Add to that the power you need to start the bike and keep things running, and you'll be draining the battery once you go below 4500rpm or so.
Dennis, would this be fitted between the exhaust and the bike? Just trying to picture exactly how it would be done...
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeSun Aug 22, 2010 9:11 am
Hi Hammy,
It would work right off the rear axle and would be centered on that location. Aux gen would be attached to the swing arm. If you put your scooter on the center stand and spin the rear wheel, you will see the axle nut spinning, This is a great place to attach a small DC voltage generating device.
Hammy
Hammy
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeSun Aug 22, 2010 9:46 am
I would love to test out something like this but have to make sure it doesn't stick out so much that it becomes victim to road debris... I plan on these farkles for when I finally start going on adventure rallies:
Touchscreen computer with GPS and internet access
Radar detector
External speakers with amp
LOUD airhorn
Helmet speakers
XM/AM/FM radio
Dual GPSes (1 displaying route, the backup displaying trip information)
Audio integrator
Conspicuity lights (I have 10Watt LEDs)
Auxiliary lights (maybe 30Watt HIDs)
Accent LED lighting under frame and wheelwells
Auxiliary fuel (probably a 3 gallon tourtank (with foam limiting the actual capacity to 2.8 gallons so I can be under 7 gallons total and not be required to keep a fuel log on events)
Voltmeter
Hydration system
See how electricity can be used up? :lol!: Some folks in the IBA use Dash shelves. I would probably mount the computer on a box that would fit over the tunnel but can be easily removed when I need to fill up the tank. The wires and chargers could all be inside the box. The GPSes would be on Dennis' center mount, the radio on one reservoir, voltmeter and control switchbox on the other reservoir, and the radar on the dash. Speakers maybe mounted on the glovebox lids.
Hey, I can dream!
KurtPerthWA
KurtPerthWA
Number of posts : 1711
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeSun Aug 22, 2010 11:54 am
What if??
what if one could set up a generator which would charge the system and go to an Aux battery as well. Generators are only really electric motors, so one could in fact use a 12volt motor which charges while going in one direction but also drives when switched to go in the other. See the benefit? Reverse gear! All for the price of an old starter motor, 12 v electric clutch and some electrickery.
The hardest bit would be making a bracket to hold it all together. All the binking lights one could mount on the dash.
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeSun Aug 22, 2010 1:00 pm
Hi All,
Just found this on Youtube: https://www.youtube.com/watch?v=MQiLKdv67FE&NR=1
This guy need s to be on some one's team. Basketball
Atlanticfun
Registration date : 2009-10-22
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeMon Sep 13, 2010 4:10 pm
Just pull the stator and have it rewound. It's the same as having the altenator rewound for cars. Lol! You guys are funny sometimes.
Sweendog
Sweendog
Number of posts : 154
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeMon Sep 13, 2010 4:19 pm
How much more juice do you think you could get out of a re-wound stator? Seems like it will be somewhat limited for space in the stator housing...
Atlanticfun
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeMon Sep 13, 2010 4:26 pm
well...... If you take a 130 from a subaru and have it rewound it right it uses the same housing and will make 180. ... so quite a jump.
It is a matter of the number of windings rather than the size.
crahar
crahar
Number of posts : 283
Registration date : 2009-08-31
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeMon Sep 13, 2010 7:44 pm
Just add one of Dennis B's trailer hitches and one of these you'll have all the power you need.Additional DC Generator 60kw-410 Wink
Craig
PostSubject: Re: Additional DC Generator   Additional DC Generator I_icon_minitimeMon Sep 13, 2010 8:55 pm
Hi Guys,
Found this little beauty on Ebay. Price is high, but the specs. are close to be a contender in this application.
OEM(s): Kubota 15531-64017,
Voltage: 12 Volts
Amps: 14 Amps
Approximate Weight: 3.12 lbs / 1.42 kg
Additional DC Generator Kg110
Additional DC Generator Kg210
» Additional Moderator
» Additional light wiring
» Mirror Extensions
» Headlight Reflector - 2 Additional Light Sockets
» Anyone interested in converting their rear turn signals to be additional brake or running lights?
