| Givi V46 opinions | |
+8Meldrew PeteP Dale N. sonuvabug gustav MikeO Cosmic_Jumper Alchik 12 posters |
Alchik Scooter Rider
Number of posts : 6 Location : Chattanooga, TN Points : 1458 Registration date : 2020-11-12
| Subject: Givi V46 opinions Thu Nov 12, 2020 1:57 pm | |
| Hi,
I'm planning on taking some long overnight trips and was thinking of adding a Givi V46 top case. Will that look and feel ok on the scooter? Just don't want to get something that's too big to be practical.
Also, are they as durable as I've been reading they are? Any other top cases I should be considering?
Thanks... |
Number of posts : 4415 Age : 81 Location : damn near Philadelphia, PA Points : 10722 Registration date : 2009-06-12
| Subject: Re: Givi V46 opinions Thu Nov 12, 2020 2:56 pm | |
| Hello Al. Welcome to the forum.
Givi is top quality stuff. Many folks here have top cases larger than V46. So I guess you’ll be okay with a 46 L top case if that fills your needs.
Also, many here have upgraded the notoriously inadequate OEM windscreen to a Givi AF214 screen which is both larger and height adjustable. There is also the less expensive Givi D214 windscreen with is larger but non adjustable. |
| Subject: Re: Givi V46 opinions Thu Nov 12, 2020 3:04 pm | |
| Thanks for the info Tim! Very helpful. Do you happen to know what larger case most folks are going with? |
Number of posts : 3832 Age : 75 Location : Seaham, Co Durham, UK Points : 9678 Registration date : 2009-06-29
| Subject: Re: Givi V46 opinions Thu Nov 12, 2020 3:25 pm | |
| I have a now obsolete E52; it isn't too big and I'd replace it with a bigger Givi if I had to. I doubt it'll wear out, though |
gustav Maxi-Scooter Rider
Number of posts : 192 Age : 72 Location : Davenport, Iowa Points : 2242 Registration date : 2019-04-13
| Subject: Re: Givi V46 opinions Thu Nov 12, 2020 3:50 pm | |
| I have a 46L Givi Monokey, purchased the back-pad at the same time. Silverwing is the only bike the wife will ride with me. We both love it, looks big, but I never take mine off. Also installed a cut down D-214 wind screen. |
sonuvabug Silver Wing Expert
Number of posts : 930 Location : Mid-Western Ontario Canada Points : 6173 Registration date : 2010-09-15
| Subject: Re: Givi V46 opinions Thu Nov 12, 2020 5:27 pm | |
| We've had a Givi V46 for about 12 years now on two different scoots. It has the optional backrest and top rack. I installed custom LED lights years ago before they had a decent set available for this case. It has stood up very well with the exception of some delamination on the little, round red lenses. Not sure why there only ... maybe UV decomposition? If I was worried about it, I'd take it apart, sand and prep them and then apply a new final clear coat. However, I'm not that worried about it.
FYI - GIVI's Monokey line is made of thicker guage PolyPro than their Monolock line. The GIVI cases go up to around 55 litres in size capacity ... I like some of the newer ones with the angular lines and I think they'd match the SWing pretty well. KAPPA is GIVI's sister line made in the same manufacturing facility.
There are also other brands of cases that members have used with success. I'll let them chime in and tell their stories. |
| Subject: Re: Givi V46 opinions Thu Nov 12, 2020 7:15 pm | |
| Great info guys! Thanks so much!
Number of posts : 1998 Age : 78 Location : Princeton, MN Points : 6051 Registration date : 2014-02-13
| Subject: Re: Givi V46 opinions Thu Nov 12, 2020 8:49 pm | |
| Hi Alchik, I have the Givi V56 on mine but I have a SWing trike. My previous Givi topbox was about the same size but not really sure of the model and size. It looked about the same. I had that one on my SWing when I had only two wheels and it handled great. |
PeteP Scooter Rider
Number of posts : 79 Location : New Mexico Points : 1606 Registration date : 2020-08-31
| Subject: Re: Givi V46 opinions Thu Nov 12, 2020 9:41 pm | |
| Al, My Givi case (46L) with rack and backrest came with the Swing when I bought it. A great case in my opinion. I keep my rain suit and electric vest stored in with plenty of room left over to pack other stuff when needed. I’ve had cheap Chinese cases on my Concours and they are night and day compared to each other, no way the cheap case was comparable. I think I’ll add lights to mine. |
Number of posts : 4214 Location : York, North Yorkshire, England UK Points : 9419 Registration date : 2010-11-16
| Subject: Re: Givi V46 opinions Fri Nov 13, 2020 4:50 am | |
| The bigger the better works for me, there's a Givi E52 on a shelf in my garage that I used for years and it stored two full face helmets, a load of groceries, or the overnight pack with my stuff for a night on an overnight ferry.
I replaced it with a Givi E55 with smoked grey reflectors to match the rear lights on the Silver Wing. I like the E55 more as it has basically the same dimensions as the E52 with the extra 3 litres due to it's slightly taller height.
The E55 is now a permanent fixture on my Forza, it doesn’t look out of place on a more compact sportier looking maxi. In fact it looks a lot better and is more useful than the over priced colour matched 45 litre top box Honda sells for the Forza.
... and that Go Cruise throttle control I've never felt necessary to use is still stored in the lid pocket of the E55. |
Lenny Scooter Rider
Number of posts : 36 Location : Uk Points : 1915 Registration date : 2019-09-08
| Subject: Re: Givi V46 opinions Fri Nov 13, 2020 7:51 am | |
| Have had the same Givi E52 on my last 8 bikes, slightly battered, (never fell off though ), I'm used to it so can't say wether it looks to big. |
Number of posts : 3309 Age : 85 Points : 9436 Registration date : 2009-08-18
| Subject: Re: Givi V46 opinions Fri Nov 13, 2020 7:58 am | |
| My E-46, made 1998, I think, has over 500,000 miles and still going strong--hole cut in top for dog's head. Worked fine on my 2 SilverWings with Givi rack. Now bolted direct to Kymco rear wing/rail. Dog likes it. |
Lenny Scooter Rider
| Subject: Re: Givi V46 opinions Fri Nov 13, 2020 8:46 am | |
| As an owner of a small dog I would love to see a photo of the box complete with the dog. |
| Subject: Re: Givi V46 opinions Fri Nov 13, 2020 11:33 am | |
| I do not take pictures---hole first cut for 15 pound Jack Russell---sized so he could not get thru hole, but head out shoulders blocked. Current passenger 8-9 pound Yorkshire---same hole but he wears safety chain. Once in Canada, I looked back and he was riding on top of box. |
| Subject: Re: Givi V46 opinions Fri Nov 13, 2020 12:10 pm | |
| I Googled 'dog in topbox'; there are loads of pictures. Here are a couple of them:
http://modernvespa.com/forum/topic100925
https://www.burgmanusa.com/threads/hump-bag-for-650.161514/ |
Number of posts : 1013 Age : 74 Location : HI Points : 4328 Registration date : 2015-12-18
| Subject: Re: Givi V46 opinions Mon Nov 16, 2020 12:23 am | |
| I have a GIVI E55 monokey on my Swing in Hawaii that came with my previous Swing. In Idaho, I installed a Shad SH46 using the mount that came with it. I prefer the Shad because you can lock the box without the key. The GIVI needs the key to open and/or lock the box. Both have a button to remove to box and use it as a suit case when traveling. |
| Subject: Re: Givi V46 opinions Mon Nov 16, 2020 3:10 am | |
| I don't think I'd carry my Givi E55 or it's smaller E52 sibling as a suitcase, neither of them are very well balanced and are rather awkward to carry fully loaded. It's much simpler to lift an inner bag out of them with all your stuff in and take that to your room.
That's the way to go with motorcycle hard panniers/saddlebags too, the backs of panniers get covered in road crap off the rear wheel in rainy weather and you really don’t want that coming off onto your bed while you're upacking.
It always amuses me on ferries when I see riders coming off the car decks and having to go up a couple of decks to their cabins, weighed down with heavy panniers, helmets, and whatever else they need. You get hot and sweaty doing this in full riding kit.
I open my top box, take out my overnight bag, put my helmet, gloves, and anything else I don't need and I'm good to go.
It's unusual these days to see anyone carrying a handled suitcase around, everyone is now so used to pulling along wheeled luggage.
Maybe that's why Givi manufactured the S410, a universal trolley base with a pull out handle for Monokey boxes. |
| Subject: Re: Givi V46 opinions Mon Nov 16, 2020 10:12 am | |
| Agree with Mildrew----if you are really riding, side boxes or top boxes get really dirty---I leave mine on. Junk I need is in my 2 Ortleib rubber bags. |
| Subject: Re: Givi V46 opinions Mon Nov 16, 2020 10:27 am | |
| Me. too. I also do the same trick with the topbox: bag of stuff out, helmet and gloves in. |
Leena H Maxi-Scooter Rider
Number of posts : 103 Location : Vaasa Finland Points : 3134 Registration date : 2016-09-17
| Subject: Re: Givi V46 opinions Tue Nov 17, 2020 10:22 am | |
