| [solved]Merge ignition trigger wires and break wires? | |
XDM© Maxi-Scooter Rider
Number of posts : 125 Location : Philly, Pennsylvania Points : 2036 Registration date : 2019-10-20
| Subject: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 12:08 am | |
| so i just brought a pair of brake master cylinders to replace a leaking right brake. (LINK HERE) This is not exactly the correct model for the silverwing but i cant find any new ones for my Silverwing so i brought these. the right master cylinder( front break) fits WONDERFULLY, looks great, fits great and breaks are drum tight when i pull it, it can stop on a dime. but the left break cylinder has extra wires and a different switch. because these cylinders are for honda MOTORCYCLES and not scooters theirs no ignition triggers in the left brake handle. what i want to do is merge/solder the ignition and brake wires together to make holding the brake starts the bike My concern is i dont want to short my system or anything, can i do this? I tried to use back the old switch, it still works but it doesn't align and can't be used.
The Bern Silver Wing Expert
Number of posts : 897 Location : Telford, UK Points : 4630 Registration date : 2014-11-20
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 6:29 am | |
| Disableing a safety device is never a good idea, the same switch is used on various models .... https://www.ebay.co.uk/itm/Switch-Stop-Front-Fits-Honda-OE-Reference-35340-KFG-000-Each-35340-KFG-000/114499608923?_trkparms=aid%3D1110009%26algo%3DSPLICE.COMPLISTINGS%26ao%3D1%26asc%3D225076%26meid%3D4537491ce33a4c1697c57e3dc8847ce4%26pid%3D100008%26rk%3D5%26rkt%3D12%26sd%3D303380920697%26itm%3D114499608923%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3Ddefault&_trksid=p2047675.c100008.m2219
google ... 35340-KFG-000 .... for sellers local to you |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 6:40 am | |
| You may just need to put the old (4 wire) switch on the new brake cylinder and also use the old brake handle —which has that extra tab to activate the switch. |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 6:42 am | |
| I forgot to mention that the old switch does not align with the new handle and can't be used |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 10:03 am | |
| There are 4 or 5 used of the correct master cylinders showing on eBay. Or why not rebuild the cylinder you have?
https://www.ebay.com/itm/Honda-2002-2013-FSC600-Silver-Wing-Scooter-OEM-Rear-Left-Brake-Master-Cylinder-/163914132696
Also check eBay for this term, “43501-MGF-305 brake”. I can’t seem to provide you with a good link for the several master cylinders shown there. |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 1:52 pm | |
- There are 4 or 5 used of the correct master cylinders showing on eBay. Or why not rebuild the cylinder you have?
Also check eBay for this term, “43501-MGF-305 brake”. I can’t seem to provide you with a good link for the several master cylinders shown there. I didn't want to put a used piece back in there as there's no telling it's condition I wanted something brand new. And I also don't feel too confident about rebuilding it. |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 2:27 pm | |
| Then here is Partzilla’ page for that brand new Honda left side master cylinder:
https://www.partzilla.com/catalog/honda/scooter/2009/fsc600d-ac-silver-wing/rear-brake-master
Not exactly cheap at ~$162 + shipping but certainly something to be very confident in.
BTW What happened to cause you to change both master cylinders? |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 3:33 pm | |
- Then here is Partzilla’ page for that brand new Honda left side master cylinder:
BTW What happened to cause you to change both master cylinders? Yeah I saw that, I brought all my pieces from partzilla but the price and the fact that I have to assemble all the pieces intimated me. The reason I had to change them is that my right cylinder was leaking and air keep getting into the line. I brought 2 brand new cylinders that came as a pair for $30 so I said let me just replace the left side too |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 4:15 pm | |
| My main question here is. Will my system/fuse short if I connect these wires together |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 4:39 pm | |
| No, the system won’t short. But that circuit is only meant to connect momentarily when the Start circuit is activated. Once started the circuit cuts out. If it is left permanently connected then something else might happen.
Caveat: It would be irresponsible and dangerous for someone to suggest that a separate switch be connected to those wires to be activated only when the bike is starting. So don’t do it. |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Wed Nov 25, 2020 4:58 pm | |
| Other then that I'd have weld and heavily modify the existing switch. I don't have a welding machine |
Number of posts : 1013 Age : 74 Location : HI Points : 4350 Registration date : 2015-12-18
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Thu Nov 26, 2020 1:25 am | |
| I think that this is well over your abilities. Take it to a Honda shop for repairs. Brakes is not something you should be experimenting on. Come on, $30 for a pair of master cylinders? Going cheap on brakes is not going to end good. But then it is your life and you can do as you please. Good luck and be safe!!!
Terry Smith Silver Wing Rider
Number of posts : 403 Age : 60 Location : Auckland, New Zealand Points : 2143 Registration date : 2020-03-11
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Thu Nov 26, 2020 6:16 pm | |
- No, the system won’t short. But that circuit is only meant to connect momentarily when the Start circuit is activated. Once started the circuit cuts out. If it is left permanently connected then something else might happen.
Caveat: It would be irresponsible and dangerous for someone to suggest that a separate switch be connected to those wires to be activated only when the bike is starting. So don’t do it. The left brake interlock is there to ensure that when you start the bike, the brake is being held on so there are no unplanned lurches if the clutch decides to engage slightly. You could easily jumper the two wires for the starter circuit so that the brake switch is bypassed, the risk then is if you start the bike without pulling the brake on AND the clutch engages. Not a big risk for an experienced rider I would think. Connecting the starter interlock wire through the left brake switch will not work in any case; the interlock switch is in series and feeds power to the starter button, and the brake switch connects to earth only via the brake bulbs. |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Thu Nov 26, 2020 6:25 pm | |
| Yea I tried it didn't work... The bike acts weird when I connect the wires. It did what I wanted to as in hold breaks and start as well as the back lights but a odd side effect was that the bike wouldn't turn off when I pulled out my key unless I hit the engine cuttof switch. So I can't do that. I'll just have to buy a new leaver and paint it black as well as learn to rebuild the pump in the cylinder. I can take the pump from the other new cylinder I couldn't use when it's time to do so. |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Thu Nov 26, 2020 8:53 pm | |
| - Terry Smith wrote:
- [Snip]
Connecting the starter interlock wire through the left brake switch will not work in any case; the interlock switch is in series and feeds power to the starter button, and the brake switch connects to earth only via the brake bulbs. You’re going to have to school me on this. 1: Are you saying (notwithstanding the above caveat) that a separate switch for the start switch interlock (Bl/W, G/R) such as mentioned above, still wouldn’t resolve the problem unless the rear brake lever was also squeezed? And... 2: If both rear brake lights were burned out (i.e. open circuit) , or both brake light bulbs were removed, that the bike wouldn’t start? I’m gonna have to dig out my 24” x 36” copy of the FSC600 wiring diagram to try to trace that start circuit to see how the brake light ground connection plays into the start circuit. Kind of reminds me of how the Helix (CN250) start circuit works too —which is something I could never quite wrap my head around. |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Thu Nov 26, 2020 9:05 pm | |
| I'm far from an electrical expert Tim! But the attached starter circuit diagram shows the positive feed coming from the battery via the solenoid/main fuse, to the ignition key switch then the engine stop relay, then the brake interlock, the starter button to the starter solenoid coil and finally to earth via the sidestand switch. The brake light circuit plays normally no part in this unless you do as the OP was proposing and hooks the two circuits together. |
Number of posts : 1384 Location : Allentown PA. Points : 4728 Registration date : 2016-01-02
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Thu Nov 26, 2020 9:41 pm | |
| He's just bypassing Left brake switch. Side stand switch if working would still not allow engine to start if down. Starter relay won't be grounded unless stand down.
Brake bulbs would have nothing to do with not starting unless some kind of short or bad ground through switch.
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Thu Nov 26, 2020 9:51 pm | |
| if my little experiment would have worked it would have been great as i still have my parking brake on before i take off anyway (i dont release that until im ready to go and is locked on parking) |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Thu Nov 26, 2020 10:09 pm | |
| - XDM:copyright: wrote:
- if my little experiment would have worked it would have been great as i still have my parking brake on before i take off anyway (i dont release that until im ready to go and is locked on parking)
If all you want is to be able to start the bike without the left brake switch, then you can just join the B/W and G/R wires together. No need to get the brake light circuit involved then and no funny business with the key switch. |
| Subject: Re: [solved]Merge ignition trigger wires and break wires? Thu Nov 26, 2020 10:32 pm | |
If all you want is to be able to start the bike without the left brake switch, then you can just join the B/W and G/R wires together. No need to get the brake light circuit involved then and no funny business with the key switch. i could that if i wanted and completely disable the safety, i was just trying to have my cake and eat it too. ill see what i do because MAN does the new brake on the right side feel AMAZING |
