Clock Reset merge I_icon_minitimeby JohnyC Today at 5:39 am
Clock Reset merge I_icon_minitimeby JohnyC Yesterday at 10:04 am
Clock Reset merge I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Clock Reset merge I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Clock Reset merge I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Clock Reset merge I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Clock Reset merge I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Clock Reset merge I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Clock Reset merge I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Clock Reset merge I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Clock Reset merge
Rabih
Number of posts : 3
Registration date : 2019-03-18
Clock Reset merge Empty
PostSubject: Clock reset    Clock Reset merge I_icon_minitimeMon Mar 18, 2019 10:25 am
Hey everyone
Im Rabih from lebanon, i have a 600cc silver wing and i had an issue
With the click and trip A, trip B, when i switch off the bike the clock use to reset by it self and also trip A ana trip B counter reset when i start it again it show 0km
Any help with this issue ???
Thanks a lot
Regards
Rabih
Number of posts : 3
PostSubject: Clock reset   Clock Reset merge I_icon_minitimeMon Mar 18, 2019 11:26 am
Hey everyone
With the clock and trip A, trip B, when i switch off the bike the clock use to reset by it self and also trip A ana trip B counter reset when i start it again it show 0km
Thanks a lot
Regards
Pastor Ron
Number of posts : 400
Registration date : 2013-02-24
PostSubject: Re: Clock Reset merge   Clock Reset merge I_icon_minitimeMon Mar 18, 2019 2:25 pm
It sounds like your reset button is stuck in the down position, try pushing it in several times to see, other than that, maybe someone else will chime in.
Number of posts : 1013
PostSubject: Re: Clock Reset merge   Clock Reset merge I_icon_minitimeMon Mar 18, 2019 9:44 pm
Did you do some electrical repairs lately? It sounds like you are losing power to the instrument panel when you turn off your bike. Maybe it is the plug going into the instrument panel, and/or plug connector under the front winged piece under the windshield.
PostSubject: Re: Clock Reset merge   Clock Reset merge I_icon_minitimeMon Mar 18, 2019 11:25 pm
Check for a bad fuse (could be blown or corroded). Also check the ground connection to the frame --both the main ground as well as the ground connection for the Combination Meter.
Rabih
Number of posts : 3
PostSubject: Re: Clock Reset merge   Clock Reset merge I_icon_minitimeTue Mar 19, 2019 9:01 am
Thank u guys .... electrician said he need to repair some wires and because B+ is lost
Number of posts : 1999
PostSubject: Clock Reset merge   Clock Reset merge I_icon_minitimeTue Mar 19, 2019 2:01 pm
OK. This is my first try at this. I hope I don't totally mess it up. I'm going to try to merge both "Clock reset" posts by Rabih. Let's see what happens.
PostSubject: Re: Clock Reset merge   Clock Reset merge I_icon_minitimeTue Mar 19, 2019 2:15 pm
Well, I gave it the old college try and didn't lose any info. Now to see if I can rename it back to Clock Reset. Wish me luck.
Well, that's a little out of my learning curve. Couldn't figure it out. Sorry Rabih. Hope I didn't mess you up too bad. But at least it's all under one tab/topic now.
WHEW! cheers
Clock Reset merge
» "Clock Reset" merge?
» Clock resets
» [solved]Merge ignition trigger wires and break wires?
» Clock issues
» ABS Light Reset
