!["Clock Reset" merge? Empty](https://2img.net/i/empty.gif) | Subject: "Clock Reset" merge? Tue Mar 19, 2019 9:31 am | |
| Anybody want to try their hand at merging the two Clock Reset posts. Both posts started by same noob about the same time. It will be interesting to see what Quick Mod Tools does to prioritize those post dates. |
![Dale N.](https://2img.net/u/3413/63/00/33/avatars/3360-93.jpg)
Number of posts : 1995 Age : 78 Location : Princeton, MN Points : 5996 Registration date : 2014-02-13
!["Clock Reset" merge? Empty](https://2img.net/i/empty.gif) | Subject: Re: "Clock Reset" merge? Tue Mar 19, 2019 1:31 pm | |
| Can you undo it if I screw it up? If you can I'll give it a try.
OK. Not sure how to do it. Unless, maybe, I rename one to "Clock reset1" or something like that then try to merge them. Other than that it tells me I can merge a topic into itself. |
!["Clock Reset" merge? Empty](https://2img.net/i/empty.gif) | Subject: Re: "Clock Reset" merge? Tue Mar 19, 2019 2:33 pm | |
| That's the way to do it, Dale.
Interesting to see that the merged posts came together by post time. Now we know.
Thanks, Dale.
!["Clock Reset" merge? Empty](https://2img.net/i/empty.gif) | Subject: Re: "Clock Reset" merge? Tue Mar 19, 2019 3:04 pm | |
| At least it worked and I didn't lose any posts or info. Whew! That was fun. |
