ABS Light Reset I_icon_minitimeby JohnyC Today at 5:39 am
ABS Light Reset I_icon_minitimeby JohnyC Yesterday at 10:04 am
ABS Light Reset I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
ABS Light Reset I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
ABS Light Reset I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
ABS Light Reset I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
ABS Light Reset I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
ABS Light Reset I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
ABS Light Reset I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
ABS Light Reset I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 ABS Light Reset
2 posters
Number of posts : 1020
ABS Light Reset Empty
PostSubject: ABS Light Reset   ABS Light Reset I_icon_minitimeSat May 09, 2020 12:55 am
Hi All,
Recently got my SWing out of storage and have had it out for a couple of rides and have had pretty good luck.  One problem that I've run in to is that when I first take off for a run around the block, the ABS light will not go out.  So I pull back into my driveway for safety's sake and shut it off.  Restarting again, I head down the road and the ABS light goes out like it's suppose to and the brakes work fine.  Has happened twice now.
Physical inspection shows nothing wrong.  The only difference is that both times were after using a battery charger to get the battery fully charged again.
So, am looking for any ideas as to why.  Don't have a lot of time to be messing with the scoot since I'm in the middle of a major renovation of a house we bought.  Anyway, any help will be appreciated.  scratch
Number of posts : 1384
PostSubject: Re: ABS Light Reset   ABS Light Reset I_icon_minitimeMon May 11, 2020 9:37 pm
ABS will set codes for high and low voltage. Battery charger could trip it if key cycle turned on while still charging. ??? or a charging system issue. There is a reset procedure by jumping a connector and clearing system or reading codes. You need a service manual. Two key cycles without a fault might be resetting the code but it's still stored in ECU.
PostSubject: Re: ABS Light Reset   ABS Light Reset I_icon_minitimeMon May 11, 2020 11:34 pm
Thanks "Mech"... Will be a few rainy days before I get back out there so we'll see what happens this third time (the charm?)… If it's still there I'll get the book out and start checking codes like you suggested... thanks again...
ABS Light Reset
» "Clock Reset" merge?
» Comments: Admore light bar vs mini light bar
» Clock Reset merge
» reset my password
» V-Light finely came on
