Mr. Dale a question or two. I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Mr. Dale a question or two. I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Mr. Dale a question or two. I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Mr. Dale a question or two. I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Mr. Dale a question or two. I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Mr. Dale a question or two. I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Mr. Dale a question or two. I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Mr. Dale a question or two. I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Mr. Dale a question or two. I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Mr. Dale a question or two. I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
3 posters
Number of posts : 1935
Mr. Dale a question or two. Empty
PostSubject: Mr. Dale a question or two.   Mr. Dale a question or two. I_icon_minitimeSat Feb 06, 2021 10:17 am
First the stock exhaust looks a tad close to that right rear fender, did you modify yours or isn't heat a problem.
Second, what is the weak link in the system, the stock drive or something in the kit'
Third, the learning curve, haven't ridden the three wheel Hondas they banned I can say anything downhill and off chamber can get iffy at times.
TIA oldwingguy
Number of posts : 3313
PostSubject: Re: Mr. Dale a question or two.   Mr. Dale a question or two. I_icon_minitimeSat Feb 06, 2021 11:15 am
All you have to do with 3 wheel trikes---one wheel in front is remember how easy your trike tipped over as a kid. I think 3 wheels ok with 2 in front---I have near 100,000 miles experience with 2 Messerschmitts----almost killed myself in Japan with the discontinued Honda 3 wheel ATV!
PostSubject: Re: Mr. Dale a question or two.   Mr. Dale a question or two. I_icon_minitimeSat Feb 06, 2021 12:18 pm
Like to add---sidecar outfits skillfully ridden can be quite safe---worked best when factory outfits were available---I have had new HD big twin with tin sidecar/MZ outfit---home brew Yamaha SR500 Jawa sidecar---Guzzi V-7 with Steib S350 ( did not have the money for different triple trees or reduced final drive gearing---bike suffered as result)
Number of posts : 1999
PostSubject: Re: Mr. Dale a question or two.   Mr. Dale a question or two. I_icon_minitimeSat Feb 06, 2021 4:00 pm
oldwingguy,
I/they didn't do anything with the stock tailpipe/muffler. There doesn't seem to be any heat problems with it. Or at least none that I've noticed or felt.
I'm not sure about any "weak link" in the system. Nothing has broken on it yet. I suppose the only main thing that's different from stock is that I have to lube the drive chain. They recommend about every 300 miles or so.
Those 3 wheel Honda ATVs from way back had, I don't know what you'd call them, Balloon Tires? This kit keeps the original front SWing tire and the two back ones are basically 14" car tires. I haven't had any fear or sensation of tipping so far. I can take curves and round-a-bouts at posted speeds.
John,
My trike as a kid had a much shorter wheel base. When I had this one put on I also had them add a 4 degree rake kit to the triple tree to extend the front wheel out a bit which was included in the $8,000 price tag. When I was doing my learning curve getting used to it I did take corners etc.a bit slower than I do now just because I wasn't used to riding a trike. Now that I've had a couple of years riding it I know my mental limits and don't worry about curves and intersections anymore.
I hope this helped answer any questions. Like I said before tho, I have no regrets doing this to my SWing. Plus, I still have all the parts they took off my SWing when they put the trike kit on.
PostSubject: Re: Mr. Dale a question or two.   Mr. Dale a question or two. I_icon_minitimeSun Feb 07, 2021 7:21 am
Thank you, nice description, ignore my other questions in the other post.
PostSubject: Re: Mr. Dale a question or two.   Mr. Dale a question or two. I_icon_minitimeSun Feb 07, 2021 9:49 pm
I also got to thinking, and yes it hurt,,, but the chain lubing every 300 miles does seem a bit much. Heck, my Wife and I took my 74 Honda CB750 from MN to FL one year and I only lubed the chain once or twice each way with no problems. It was a nice heavy duty O-Ring chain just like this one. Even tho they say/recommend 300 miles I never have lubed it that often and the chain hasn't "stretched" either. It's still just as "tight" as the first day I got it.
PostSubject: Re: Mr. Dale a question or two.   Mr. Dale a question or two. I_icon_minitimeMon Feb 08, 2021 7:11 am
Dale I wonder if that's because the transmission has taken some of the load off while starting up thus easing the load on the chain, and the same for each shift point on a standard bike transmission.
PostSubject: Re: Mr. Dale a question or two.   Mr. Dale a question or two. I_icon_minitimeMon Feb 08, 2021 7:25 am
[quote] Dale I wonder if that's because the transmission has taken some of the load off while starting up thus easing the load on the chain, and the same for each shift point on a standard bike transmission.[quote]
That could very well be the case.
» Hi, I'm Dale M
» Dale's Birthday Today
» Dale's pictures
» Dale - Sorry for your lost
» Dale - Ummmmm
