| Subject: GIVI mount Tue Feb 16, 2010 6:23 pm | |
| Has any installed a GIVI mount for a top box? The instructions that came with it suck, any input would be a great help.Thanks in advance. Roger |
| Subject: Re: GIVI mount Tue Feb 16, 2010 6:49 pm | |
| Roger, Hang on to your hat. There are a ton of people that have installed top boxes here and would be happy to help you. |
| Subject: Re: GIVI mount Tue Feb 16, 2010 8:32 pm | |
| You basically have to remove the wing from the bike then remove the bottom cover from the wing and drill 4 holes into the wing. The holes are drilled thru the 4 spots that are made to mount a rack to the wing. They are quite obvious. Then take your time and try to follow the givi mounting instructions. They are a little tough to follow but its pretty easy. Took me about half an hour to do it. |
| Subject: Re: GIVI mount Tue Feb 16, 2010 8:59 pm | |
| Subject: Re: GIVI mount Tue Feb 16, 2010 10:45 pm | |
| Thanks JeffR for the links,and jeffp thanks for the explanation. I know I can do it now.I have the service manual so taking it apart should not be a problem. I also have the light kit to wire in,witch I think I will put on with the brake light. Thank you jeffp and JeffR for your fast response. Roger |
| Subject: Re: GIVI mount Wed Feb 17, 2010 4:13 am | |
| I followed Jeff's pictorial thinking, "It must be more difficult than that; where's the catch?" but it isn't and there isn't one! The hardest part was stopping the spacers falling out whilst putting in the bolts. I bought a new drill-bit beforehand, just to be on the safe side. I did the deed on the front lawn very methodically (with pauses) and it took less than 40 minutes IIRC. |
