Givi AF214 Mount I_icon_minitimeby JohnyC Today at 5:39 am
Givi AF214 Mount I_icon_minitimeby JohnyC Yesterday at 10:04 am
Givi AF214 Mount I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Givi AF214 Mount I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Givi AF214 Mount I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Givi AF214 Mount I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Givi AF214 Mount I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Givi AF214 Mount I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Givi AF214 Mount I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Givi AF214 Mount I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Givi AF214 Mount
NWSSC
Givi AF214 Mount Empty
PostSubject: Givi AF214 Mount   Givi AF214 Mount I_icon_minitimeFri Aug 22, 2014 10:34 am
I bought a used Givi Air Flow windscreen however the instructions indicate that I should be using some sort of a mounting bracket.
The windshield mounts in the same location as the OEM screen, blah..blah..blah. So why the need for the additional mounting bracket? It seems to be only a bracket which fits under the windscreen and under the Garnish panel, not some sort of support brace. What does it do? What is the risk of not having that bracket?
Also I've seen reports of the top half of the Air Flow coming off at speed. Is there something that can be done about that -aside from insuring that the clamps are tight? I emailed Givi regarding that problem and they've denied any knowledge of it.
NWSSC
NWSSC
Number of posts : 418
PostSubject: Re: Givi AF214 Mount   Givi AF214 Mount I_icon_minitimeFri Aug 22, 2014 12:48 pm
Hi Tim. It has been quite some time since I instilled a optional windshield but there is a location for a another bracket for more support for a larger windscreen.I believe the area is threaded but the front cover must be drilled out to access the threads.Do you have the bracket? I believe it is short but with a couple of bends.If you have the bracket it will give you some idea where to drill out the cover. I'm sure some one will come up with a picture. It is not that difficult and the option probably is up to the individual.
Howard
PostSubject: Re: Givi AF214 Mount   Givi AF214 Mount I_icon_minitimeFri Aug 22, 2014 1:24 pm
Thanks for your reply Howard. Unfortunately I don't have the brackets. I just looked at JeffR's tutorial and saw the installation step about those brackets. I'll have to order the D214KIT from Givi, but their photo only shows the brackets and hex bolts.
Some of the kits for other bikes seem to have actual brace rods going from the lower windscreen to the meter cover.
I'm concerned about the top half coming off when I'm zipping my way across North Dakota though affraid
PostSubject: Re: Givi AF214 Mount   Givi AF214 Mount I_icon_minitimeFri Aug 22, 2014 5:05 pm
I have two Silverwings both have AF214 windscreens one has the bracket installed and the other one doesn't. I've probably put 35,000 to 40,000 miles the one without the bracket and never had a problem with it. And it is the one I use for all my long and highway miles. So you can buy the kit if it will give you comfort but I would not bother. It's your bike so definitely do what makes you comfortable after all you have to ride it and if you're not comfortable the ride's not fun.
Number of posts : 4218
PostSubject: Re: Givi AF214 Mount   Givi AF214 Mount I_icon_minitimeFri Aug 22, 2014 5:22 pm
You've seen reports of the top half of the Airflow coming off at speed, oh dear that's awful where did you read that ?   scratch
flavioguy
Number of posts : 34
Registration date : 2014-06-28
PostSubject: Re: Givi AF214 Mount   Givi AF214 Mount I_icon_minitimeSun Aug 24, 2014 11:13 am
I just installed this windscreen two weeks ago and did have the brackets. It does seem to provide some additional support but it is not that drastic. Installation instructions also specify some drilling. I was not willing to do that....seemed extreme.
As per the instructions and pics kindly provided on this forum, push very gently when tightening down the 6 screws. Those rubber grommets can disappear quickly into never-never land. Also something I learned with my previous scoot, cover any and all openings around the windscreen area when working (rags/socks, whatever). Dropping a screw or anything small is rarely retrievable once it falls into the "headlight/cowl" area.
Number of posts : 3837
PostSubject: Re: Givi AF214 Mount   Givi AF214 Mount I_icon_minitimeSun Aug 24, 2014 11:35 am
The only drilling is through the very thin plastic which masks the captive nuts, one either side.
As has been said elsewhere on the forum it is quite possible to break through/drill the holes with a sharpish drill-bit held in the hand. Certainly, if one uses a mechanical drill, a minimum of pressure is required.
Someone (can't remember who) suggested recently that it was also possible to melt a hole through using a soldering iron.
PostSubject: Re: Givi AF214 Mount   Givi AF214 Mount I_icon_minitimeSun Aug 24, 2014 12:35 pm
It was a bloke on the Muppets forum who's never had a Silver Wing.  Smile
PostSubject: Re: Givi AF214 Mount   Givi AF214 Mount I_icon_minitimeSun Aug 24, 2014 3:04 pm
Smile
Givi AF214 Mount
» Givi AF214 Cautions
» AF214 Givi windshield
» Givi AF214 Screen
» Where did you buy your Givi AF214 windshield?
» Givi AF214 damaged
