2008 Swing won’t start?  I_icon_minitimeby MikeO Yesterday at 6:23 pm
2008 Swing won’t start?  I_icon_minitimeby POCAHONTAS Yesterday at 6:05 pm
2008 Swing won’t start?  I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
2008 Swing won’t start?  I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
2008 Swing won’t start?  I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
2008 Swing won’t start?  I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
2008 Swing won’t start?  I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
2008 Swing won’t start?  I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
2008 Swing won’t start?  I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
2008 Swing won’t start?  I_icon_minitimeby kbcmdba Mon Nov 04, 2024 7:56 pm
Dabutcher
Number of posts : 30
Registration date : 2021-03-21
2008 Swing won’t start?  Empty
PostSubject: 2008 Swing won’t start?    2008 Swing won’t start?  I_icon_minitimeTue Apr 20, 2021 8:21 pm
I sold my 2003 and only have my 2008 model. New Deka battery. Won’t even turn over? Dead. Old battery worked fine. Just new battery peace of mind. Hooked up old battery and nothing with that either. Lights and dash board work fine? Any and all help would be greatly appreciated. Bike has 5K miles and was just running for a fifteen mile ride Saturday. My guess is kickstand switch or brake switch? D
Number of posts : 578
PostSubject: Re: 2008 Swing won’t start?    2008 Swing won’t start?  I_icon_minitimeWed Apr 21, 2021 6:44 am
Need to check basics 1st, check all fuses including 30 amp at starter relay, check/clean your grounds, kinda below starter relay(area/cavity above swingarm)several, you state is dead ?, but you have dash lights  Shocked, is fuel pump priming ?. In general your idea of kickstand or brake limit switch are the "no crank" causes, easy check per Service Manual page 20-11 will check operation of both.
 IAC this is INFO/PSA for those with mechanical/electrical know how/skills. Good luck.
Number of posts : 1013
PostSubject: Re: 2008 Swing won’t start?    2008 Swing won’t start?  I_icon_minitimeThu Apr 22, 2021 3:09 pm
Two things come to mind.
1. You blew the main fuse when connecting the new battery.
2. The engine kill switch on the right handle bar is on.
Good luck!
Number of posts : 1384
PostSubject: Re: 2008 Swing won’t start?    2008 Swing won’t start?  I_icon_minitimeThu Apr 22, 2021 7:48 pm
Easy enough to jump front brake switch with some wire. kickstand switch a lot harder to reach. Check all the fuses under the seat for power.  There are 2 30 amp fuses likely 1 for each box. Only takes a touch to short something with full battery voltage.
Dabutcher
PostSubject: Re: 2008 Swing won’t start?    2008 Swing won’t start?  I_icon_minitimeFri Apr 23, 2021 8:37 pm
I don’t know what happened? Next day started right up ? Maybe I did not pull the brake in far enough? Been riding it every day. No issues. Thanks. D
Number of posts : 1935
PostSubject: Re: 2008 Swing won’t start?    2008 Swing won’t start?  I_icon_minitimeSat Apr 24, 2021 6:40 am
Squeezing the brake, any squeeze firm that's enough to keep the bike from moving should do the trick, left hand.
PostSubject: Re: 2008 Swing won’t start?    2008 Swing won’t start?  I_icon_minitimeSat Apr 24, 2021 7:22 am
 On my bike I have to pull rear brake lever fairly hard to hear/activate the start limit switch ??, I wonder if there's and issue ??, IAC I have done the "Parking Brake Switch Mod" to allow bike to start with PB set/stand down, love it  Cool
» 2008 SWing for Sale
» New here, Hello from Santa Cruz, 2008 SWing
» how to start a 03 swing
» Swing won't start!
» Swing won't start
