| Gasket Replacement | |
mergus Scooter Rider
Number of posts : 7 Location : Milwaukee Points : 1596 Registration date : 2020-07-22
| Subject: Gasket Replacement Sun Apr 25, 2021 12:55 pm | |
| Has anyone replaced part GASKET, L. COVER 11395-MCT-000, when replacing the drive belt? If the image attached to this message comes through, it's item 13. Thank you!!! - Attachments
- (76 Kb) Downloaded 17 times
Number of posts : 580 Age : 65 Location : Ocala, FL Points : 2023 Registration date : 2020-12-26
| Subject: Re: Gasket Replacement Sun Apr 25, 2021 2:29 pm | |
| In most cases replacement is not requred, I personally have not in numerous removals of cover, just wipe down area and make sure seal is still pliable/flexible, no flat spots or damaged. In a pinch you could apply a light coat of Motoseal1 , Honda Bond, ThreeBond, etc., especially if you ride your scooter in rain a lot. |
Number of posts : 1384 Location : Allentown PA. Points : 4728 Registration date : 2016-01-02
| Subject: Re: Gasket Replacement Sun Apr 25, 2021 4:24 pm | |
| No but if it's pinched or damaged I would. Watch that rear speed sensor wires some have pinched them and speedo stops working. |
Number of posts : 1037 Location : Teesdale, UK Points : 4230 Registration date : 2016-05-15
| Subject: Re: Gasket Replacement Mon Apr 26, 2021 2:24 am | |
| No, but I really should as its most kindly described as a minging mess! Next time I'm in there I'll do it. |
| | | Loosemarbles Site Admin
Number of posts : 1607 Age : 63 Location : South East England Points : 4756 Registration date : 2016-10-01
| Subject: Re: Gasket Replacement Mon Apr 26, 2021 5:40 am | |
| I replaced mine a few years ago but the old one was still useable. If the gasket looks OK it could be worth just carefully removing it for inspection. As stated above, if it looks OK and is still flexible then just clean it and also clean the groove in the casing to ensure a snug fit.
If there's no visible damage, it's probably OK. |
| Subject: Re: Gasket Replacement Mon Apr 26, 2021 7:52 am | |
| Far more likely to be in need of replacement, and important IMHO, is the foam filter (#6) on the belt case cover. Not only does it stop debris and small children from getting in there but it is the only way the variator, belt and rear pulley receive cooling air flow. And the filter has a bad habit of disintegrating if neglected. |
| Subject: Re: Gasket Replacement Mon Apr 26, 2021 11:35 am | |
