| silverwing 600 muffler gasket | |
themastermix Scooter Rider
Number of posts : 9 Location : Lebanon Points : 5355 Registration date : 2010-04-11
Terry Smith Silver Wing Rider
Number of posts : 403 Age : 60 Location : Auckland, New Zealand Points : 2143 Registration date : 2020-03-11
| Subject: Re: silverwing 600 muffler gasket Sat Aug 22, 2020 10:10 pm | |
| 18391-ML8-000 is definitely the right part number, and looks to be correct across all years.
https://www.partzilla.com/catalog/honda/scooter/2009/fsc600a-ac-silver-wing/muffler
Maybe you've been sent the wrong part?
The Bern Silver Wing Expert
Number of posts : 897 Location : Telford, UK Points : 4630 Registration date : 2014-11-20
| Subject: Re: silverwing 600 muffler gasket Sun Aug 23, 2020 5:32 am | |
| Is it the inside diameter that appears too small bud ? If so take a small file to the header pipe, file gently until you get it back to steel, these seals have a habit of 'bonding' themselves in place. |
| Subject: Re: silverwing 600 muffler gasket Sun Aug 23, 2020 7:10 am | |
| I always carried one of the gaskets/packings with me---they are another items shops do not carry in stock. Of course bike runs without the gasket and probably with no harm---but the noise on long ride can drive you nuts! |
Number of posts : 1607 Age : 63 Location : South East England Points : 4756 Registration date : 2016-10-01
| Subject: Re: silverwing 600 muffler gasket Sun Aug 23, 2020 8:16 am | |
| I recently fitted one of these. I found it a tight fit but a little brute force helped it on.
Mine did appear 'slightly' too small at the inside diameter and removing the remains of the old one took a while, I think it was this which made the gasket appear too small. I'm sure you have the correct part. |
| Subject: Re: silverwing 600 muffler gasket Sun Aug 23, 2020 10:00 am | |
| - Terry Smith wrote:
- 18391-ML8-000 is definitely the right part number, and looks to be correct across all years.
i have removed the muffler and taken some measurements using a caliper ..the outer diameter of my exhaust pipe is 43mm that's what the inner diameter of the gasket should be ....the inner diameter of my muffler (outer diameter of gasket) is 49mm so 18391-ML8-000 is definitely not the correct part and is very smaller in size |
| Subject: Re: silverwing 600 muffler gasket Sun Aug 23, 2020 10:05 am | |
| Try your Honda dealer and let them figure it out. |
| Subject: Re: silverwing 600 muffler gasket Sun Aug 23, 2020 12:50 pm | |
| Hmmm, a quick search on 18391-ML8-000 shows ...........
Genuine Honda exhaust gasket. This exhaust gasket was used on the header pipe #1 and #3 where they insert into the collector box on the CB400F. Avoid exhaust leaks due to old gaskets!
***Note these Dimensions: I.D. - 31.9mm / O.D. = 37.3mm / Width 25.4mm
Honda part number: 18391-ML8-000 ......................................................................................................................................
So that looks to be the wrong item number bud, what you actually need is ...... PACKING,MUFFLER (NAS) product number: 18392MJ4670
For complete fitting list see here ..... https://www.bike-parts-honda.com/honda-motorcycle/assignment_spare_parts/18392MJ4670
mergus Scooter Rider
Number of posts : 7 Location : Milwaukee Points : 1596 Registration date : 2020-07-22
| Subject: Re: silverwing 600 muffler gasket Sun Aug 23, 2020 8:39 pm | |
| - Loosemarbles wrote:
- I recently fitted one of these. I found it a tight fit but a little brute force helped it on.
Mine did appear 'slightly' too small at the inside diameter and removing the remains of the old one took a while, I think it was this which made the gasket appear too small. I'm sure you have the correct part. How did you go about removing the old gasket? |
| Subject: Re: silverwing 600 muffler gasket Mon Aug 24, 2020 9:29 am | |
| - The Bern wrote:
- Hmmm, a quick search on 18391-ML8-000 shows ...........
For complete fitting list see here ..... https://www.bike-parts-honda.com/honda-motorcycle/assignment_spare_parts/18392MJ4670 thank you so much that was exactly the one i'm looking for |
