jerry-d Scooter Rider
Number of posts : 12 Location : tampa Points : 965 Registration date : 2022-04-19
| Subject: ducati muffler on silverwing Thu Oct 20, 2022 12:20 pm | |
Faston Bulbous Scooter Rider
Number of posts : 9 Points : 4751 Registration date : 2011-12-02
| Subject: Re: ducati muffler on silverwing Thu Oct 20, 2022 8:23 pm | |
| Looks sad plumbed straight back like that. The least you could do is to angle it up like a traditional aftermarket muffler. |
steve_h80 Silver Wing Guru
Number of posts : 1037 Location : Teesdale, UK Points : 4230 Registration date : 2016-05-15
| Subject: Re: ducati muffler on silverwing Fri Oct 21, 2022 3:47 am | |
| I was just thinking the same, both cans at high level would look good. But I expect it would be a nightmare plumbing them in around the swing arm, relocating the airbox, trying to make it run right after all that. On reflection you've most likely made great fight choice. |
Kneedtospeed Scooter Rider
Number of posts : 11 Location : Pittsburgh Points : 995 Registration date : 2022-03-12
| Subject: Re: ducati muffler on silverwing Mon Oct 31, 2022 1:38 pm | |
| Does your Mother know about this? |
| Subject: Re: ducati muffler on silverwing Fri Nov 25, 2022 6:07 pm | |
| - Faston Bulbous wrote:
- Looks sad plumbed straight back like that. The least you could do is to angle it up like a traditional aftermarket muffler.
seems a strange comment given the stock exhaust mounts at the same angle. I like the way it looks. I will say it gets louder on right turns as the tip is closer to the highly reflective ground. the muffler mount was a temporary thing. the inlet is straight. if one wanted to use one of those s pipes you could. higher angles on the exhaust are FAR easier on the ears. but the s pipe would be moving pipe about 8 inches farther rear. not something I will be interested in. this is not an expensive aftermarket muffler. its a 40 dollar muffler on ebay. and it sounds and performs amazing. not for everyone. but sure puts a big smile on my face every time I ride it. |
| Subject: Re: ducati muffler on silverwing Fri Nov 25, 2022 8:20 pm | |
