Location of fuel pump relay I_icon_minitimeby john grinsel Today at 4:14 pm
» Rear wheel valve stem
Location of fuel pump relay I_icon_minitimeby JohnyC Today at 11:53 am
Location of fuel pump relay I_icon_minitimeby COMick Yesterday at 6:13 pm
Location of fuel pump relay I_icon_minitimeby xwelder Yesterday at 12:31 pm
Location of fuel pump relay I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Location of fuel pump relay I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Location of fuel pump relay I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Location of fuel pump relay I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Location of fuel pump relay I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Location of fuel pump relay I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
3 posters
IronSky
Number of posts : 32
Registration date : 2021-06-24
Location of fuel pump relay Empty
PostSubject: Location of fuel pump relay   Location of fuel pump relay I_icon_minitimeFri Jul 02, 2021 8:06 am
Hi can someone guide me to the location of fuel pump relay to see if I can swap it. It’s for 2003 Honda silverwing
Number of posts : 580
PostSubject: Re: Location of fuel pump relay   Location of fuel pump relay I_icon_minitimeFri Jul 02, 2021 11:32 am
Under LH side cover, one with SW logo, there's a sequence to removing that panel, ask if not sure, could break it, https://www.silverwing600.com/t1010-left-rear-cover-removal-pictorial-main-fuse-access  I like to remove the rear wing 1st, just 4 bolts.
PostSubject: Re: Location of fuel pump relay   Location of fuel pump relay I_icon_minitimeFri Jul 02, 2021 11:41 am
BTW you can reach the back of the spring clips from the tail light access door in storage compartment, pushing the back of these plastic post is better than prying side cover(break !!), spraying some plastic friendly lube like silicone or dish soap on metal clips will help loosen clips, they can be fairly tight !!
Number of posts : 403
PostSubject: Re: Location of fuel pump relay   Location of fuel pump relay I_icon_minitimeSun Jul 04, 2021 11:17 pm
Location of fuel pump relay Fuel_s10
Location of fuel pump relay Fuel_s12
» turn signal flasher relay location
» Fuel tank removal (fuel pump replacement)
» Where is the Fan Motor relay located?
» fuel pump issue
» NO fuel pump, rats got into it!
