IronSky Scooter Rider
Number of posts : 32 Location : Colorado Points : 1298 Registration date : 2021-06-24
| Subject: Passenger FootPeg Socket Bolt size? Tue Jul 06, 2021 8:16 pm | |
| I do not have a tool to remove passenger footpeg socket bolts. So what is the size of the socket to remove it? |
zrx212 Silver Wing Expert
Number of posts : 580 Age : 65 Location : Ocala, FL Points : 2023 Registration date : 2020-12-27
| Subject: Re: Passenger FootPeg Socket Bolt size? Tue Jul 06, 2021 8:25 pm | |
| 8mm Allen, there's a lower support hole for plastic side covers with a rubber grommet on footpeg mount, kinda push upper part of footpeg in after removing bolts, then slide aft, be gentle, soapy water helps. |
| Subject: Re: Passenger FootPeg Socket Bolt size? Tue Jul 06, 2021 8:27 pm | |
| - zrx212 wrote:
- 8mm Allen, there's a lower support hole for plastic side covers with a rubber grommet on footpeg mount, kinda push upper part of footpeg in after removing bolts, then slide aft, be gentle, soapy water helps.
Thanks |
Terry Smith Silver Wing Rider
Number of posts : 403 Age : 60 Location : Auckland, New Zealand Points : 2143 Registration date : 2020-03-11
| Subject: Re: Passenger FootPeg Socket Bolt size? Tue Jul 06, 2021 8:58 pm | |
| Get some silicone grease/spray onto any rubber grommets that you come to. Thank me later. |
| Subject: Re: Passenger FootPeg Socket Bolt size? Wed Jul 07, 2021 10:46 am | |
| - Terry Smith wrote:
- Get some silicone grease/spray onto any rubber grommets that you come to. Thank me later.
Very important tip to prevent breaking plastic parts, Plumbers or food grade silicone seal grease works good, no harsh chemicals that could attack plastics and very waterproof, usually cheaper and available in small tubes, all my scooter grommets, panel metal clips and even the floor rubber mats nubs have a generous coating. |
