Fork Tube socket size I_icon_minitimeby JohnyC Today at 5:39 am
Fork Tube socket size I_icon_minitimeby JohnyC Yesterday at 10:04 am
Fork Tube socket size I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Fork Tube socket size I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Fork Tube socket size I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Fork Tube socket size I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Fork Tube socket size I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Fork Tube socket size I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Fork Tube socket size I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Fork Tube socket size I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
thomphoto
thomphoto
Number of posts : 188
Registration date : 2009-06-11
Fork Tube socket size Empty
PostSubject: Fork Tube socket size   Fork Tube socket size I_icon_minitimeThu Sep 09, 2010 2:55 pm
Can someone tell me the socket size of the fork cap bolt on the fork tube. The one that you remove to drain the fork oil. I'm installing the HyperPros and need to get an impact wrench socket.
Thanks,
Wendell
http://wendellthompsonfineart.com
GaryL
GaryL
Number of posts : 237
PostSubject: Re: Fork Tube socket size   Fork Tube socket size I_icon_minitimeThu Sep 09, 2010 5:40 pm
Could it be a (GASP) ENGLISH size!? Something like 7/8ths inch or so? I don't have a conversion chart, but I know that a 15/16ths box wrench fits the oil drain plug perfectly.
edbancro
Number of posts : 160
PostSubject: Re: Fork Tube socket size   Fork Tube socket size I_icon_minitimeThu Sep 09, 2010 6:17 pm
bigbird wrote:
Thanks,
Wendell
Your timing is impeccable. I am doing the same job either later today or tomorrow. I will be loosening my caps while the forks are still on the Swing (my front cover is off for other work), so I have to use a wrench. I checked this morning and it's a rather loose fitting 22mm. I didn't have a 21mm wrench so I borrowed one to make sure. It's definitely not 21mm. I may just use a Crescent wrench, as the 22mm combination has too much free play for my liking. Anyone else find the fork caps to be a loose fitting 22mm?
I don't remember what size I used (definitely metric, sounds like it was probably a 22mm), but, whatever size it was, I don't remember thinking it was too loose or wanting something in-between. I definitely used a 6-point socket, if you're using a 12-point then it might feel looser.
I would strongly recommend using a socket or closed end wrench (preferably 6-point) over an open end or Crescent wrench whenever feasible: A socket or closed-end grabs on all 6 sides, Crescent or open-end only grabs on 2, so you run a lower risk of rounding off the cap with a closed-end or socket. I think most good 6-point sockets, particularly impacts, have a little rounded cut-out at the corners (do a Google image search and you can see what I mean). That design applies force to the sides of the nut rather than the corners, which reduces round-off.
edbancro
PostSubject: Re: Fork Tube socket size   Fork Tube socket size I_icon_minitimeThu Sep 09, 2010 10:12 pm
bigbird wrote:
The torque on the fork cap is only 17 ft.lbs. I would think that rounding of the bolt wouldn't be a problem. It's not like they're cranked on like lug nuts.
True, it's probably not a big concern, but they are aluminum, so a light touch is in order - don't go manhandling it or try to show off by torquing it to 18 ft-lb Wink
thomphoto
thomphoto
PostSubject: Re: Fork Tube socket size   Fork Tube socket size I_icon_minitimeThu Sep 09, 2010 11:03 pm
Thanks to all of you for the great information. Is it possible to loosen the cap while the forks are still intact without taking off the front tupperware? I have an impact wrench and planned on using that after I take the forks off. I'll try the metric 22 and see if that works. Seems like the manual would specify the nut sizes, but doesn't.
edbancro
PostSubject: Re: Fork Tube socket size   Fork Tube socket size I_icon_minitimeThu Sep 09, 2010 11:10 pm
I don't know for sure, but it doesn't seem likely - there's probably too much other stuff in the way. You might try removing the right glove box and/or the handle bar covers (i.e., the easier parts) and see how it looks from there. Getting them apart won't be an issue with the impact - but the reassembly is tricky without a vise.
» Socket size for oil drain plug???
» What size of the spark plug socket?
» Passenger FootPeg Socket Bolt size?
» Fork tube jammed
» Fork tube & spindle issue
