ronjr009 Maxi-Scooter Rider
Number of posts : 180 Location : Greeneville, TN Points : 6043 Registration date : 2008-12-28
| Subject: Interesting SW Info/Resource from Italy Mon Feb 22, 2010 7:32 pm | |
| My brain was fried like an egg after reading a half a dozen or so of the technical topics from this italian website due to the broken translation of the english. Still though, I was able to get a basic understanding of it. There is a lot of interesting info for those inquiring minds. There are even some nice pics..... Here's the link http://66.163.168.225/babelfish/translate_url_content?.intl=us&lp=it_en&trurl=http%3a%2f%2fwww.silverwing400.it%2findex.php |
dspevack Silver Wing Guru
| Subject: Re: Interesting SW Info/Resource from Italy Mon Feb 22, 2010 7:58 pm | |
| Yes. This page in particular http://66.163.168.225/babelfish/translate_url_content?.intl=us&lp=it_en&trurl=http%3a%2f%2fwww.silverwing400.it%2findex.php%3foption%3dcom_content%26task%3dblogsection%26id%3d6%26Itemid%3d44 has their technical blog with a lot of how-tos. Its at the bottom of avery good review of the new GIVI airflow unit, and it links to a second page of howtos also. Dan |
| Subject: Re: Interesting SW Info/Resource from Italy Mon Feb 22, 2010 10:09 pm | |
| Neither link works for me. I keep getting: NOT FOUND The requested URL was not found on this server. Can some one post the original link w/o the translation please. maybe that'll work for me Tim |
| Subject: Re: Interesting SW Info/Resource from Italy Tue Feb 23, 2010 7:03 pm | |
| Hey Tim,
Try this one. And then in the right hand corner is a button for english.
http://www.silverwing400.it/index.php?option=com_content&task=blogsection&id=6&Itemid=83 |
| Subject: Re: Interesting SW Info/Resource from Italy Thu Feb 25, 2010 11:31 pm | |
| Check out the Technical Archives. About half way down the list is the entry: "Defective clutch Honda FJS 400, the solution" (Difellosita frizione Honda FJS 400, la soluzione). While Bablefish's mangled transliteration leaves a lot to be desired, if you really work at understanding the text it appears as if you may be able to effect the clutch performance by drilling lightening holes in the clutch shoes. While the entry does cover this as a fix for a Silverwing 400cc clutch noise issue, there is no reason that the modified clutch shoes would not also tweak the FJS 600 clutch as well. Lighter clutch shoes should produce a similar effect as changing to stronger clutch springs. However, drilling holes in the clutch shoes is an irreversible tweak. So ya better know what you're going after before you break out the DeWalt. |
