| ABS Light Fail To Extinguish First Time Around | |
+5Loosemarbles r1dbb Erdoc48 SWingSteve Green7 9 posters |
Green7 Scooter Rider
Number of posts : 37 Location : UK Points : 1209 Registration date : 2021-07-26
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: ABS Light Fail To Extinguish First Time Around Fri Sep 03, 2021 8:31 am | |
| Hi,
I've searched on the subject and can see that ABS light issues can be down to a battery that is not fully charged but was wondering if my issue had been experienced by other riders
Basically on start up and ride off the ABS light stays on. Stop and turn off the engine, restart and ride away and the light goes out. This happens each and every time I use the bike, the second start up and ride away extinguishes the ABS light
I plan to investigate fully at the weekend but was just wondering if someone had experienced this before and what their fix was |
SWingSteve Scooter Rider
Number of posts : 17 Location : Eastern WV Points : 840 Registration date : 2022-06-14
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Wed Nov 23, 2022 9:40 pm | |
| Hi Green7, I just saw your thread when I was searching this same problem. While I don't quite know why it's happening, I do experience something very similar. Mine seems when started cold in the morning and I idle for any length of time without the park brake on, to light and not go away when riding, until I stop, shut off and start off again. It does seem if I start and pull away right afterwards then it goes out every time. Strange. The couple of times I did start it and let it idle when my park brake was applied it went away afterwards once I released the park brake and set off quickly. |
Erdoc48 Touring Scooter Rider
Number of posts : 373 Age : 60 Location : Myrtle Beach, SC Points : 1218 Registration date : 2022-05-31
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Thu Nov 24, 2022 11:55 am | |
| I’m not sure about this, but isn’t that the normal function of the ABS system (meaning that seems like the way it should be)? Mine is the same- stays on until I ride away (while the engine is on), then the ABS light goes out. |
r1dbb Scooter Rider
Number of posts : 8 Location : Lincoln UK Points : 5162 Registration date : 2010-07-30
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Thu Nov 24, 2022 3:20 pm | |
| That is what it is supposed to do same with any ABS. ECU has to check all is well before extinguishing the light - if it stays on then there is a problem - similarly if it doesn't come on at all |
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Fri Nov 25, 2022 3:38 am | |
| I don't have ABS but reading Green7's and SwingSteve's problems has left me a little confused.
Green7, are you riding, after setting off, for long enough to allow the light to go out before switching off and setting off a second time?
SwingSteve's problem sounds similar but with a relation to the parking brake light.
In either case, they don't sound like normal behaviour. More information might be needed here to help further. |
terrier Touring Scooter Rider
![terrier](https://2img.net/u/3413/63/00/33/avatars/4057-36.png)
Number of posts : 301 Age : 74 Location : Northumberland, UK Points : 3655 Registration date : 2015-08-12
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Fri Nov 25, 2022 2:01 pm | |
| The abs light doesn't extinguish until you get to around 6 mph. If it's still on after that then there's a problem
zrx212 Silver Wing Expert
Number of posts : 553 Age : 65 Location : Ocala, FL Points : 1922 Registration date : 2020-12-26
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Sun Nov 27, 2022 7:47 pm | |
| It obvious you have and intermittent issue, the troubleshooting procedure is very easy/straightforward on chapter 17 of Service Manual, but I suspect more of a poor/bad/wet/dirty connection somewhere in the system, check security of sensors at wheels and speed sensor aft end of cvt case, also check/clean all sensors wiring connecting plugs, etc. Also, common ground point behind left cover, for corrosion, etc., easier things 1st, lastly the connector at ABS modulator behind front cover/fairing BTW, I don't believe is a fuse but remove and reinstall just to clean contacts, Good luck. |
DickO Founding Member
![DickO](https://2img.net/u/3413/63/00/33/avatars/13-78.jpg)
Number of posts : 1019 Age : 79 Location : Atchison, KS Points : 6888 Registration date : 2008-12-23
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Mon Nov 28, 2022 1:35 pm | |
| Just FYI, but little over a year ago, took my SW out of storage to clean it up for operation... after a wash and general checkup, rode it around a circuitous route back to my driveway and saw the ABS lite still on... Shut the bike off, restarted and took off again... the lite went off as normal so I repeated my route and started over after again giving it a thorough visual lookover... operation has been normal ever since... so, good luck... hope yours isn't too difficult to solve... and I might add that I had been tinkering with my battery system too and may have had some sort of effect on it as has been mentioned above... |
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Tue Nov 29, 2022 8:16 pm | |
| If the ABS light stays on it has a stored code you need to jump the connector and follow the procedure to read it. Do you have a service manual? Section 17-2.
Could be anything from a bad sensor, wheel bearing or just some metal sticking to sensor they are magnetic. Find the code front or rear will give you a place to start.
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Wed Nov 30, 2022 1:50 am | |
| Hi, The fault was traced to a loose battery connection. I just nipped the screw on one of the terminals up and problem solved Thanks |
![ABS Light Fail To Extinguish First Time Around Empty](https://2img.net/i/empty.gif) | Subject: Re: ABS Light Fail To Extinguish First Time Around Wed Nov 30, 2022 4:42 am | |
| Aah, those pesky battery terminals. Glad to hear you fixed it and thanks for posting the solution. It had the makings of a malfunction ![thumbs up](/users/3413/63/00/33/smiles/1780003104.gif) |
