| drive belt replacement | |
dmosemorris Scooter Rider
Number of posts : 7 Location : NW Washington Points : 1189 Registration date : 2021-08-29
| Subject: drive belt replacement Thu Sep 23, 2021 9:17 pm | |
| Any advice about drive belt replacement. The official shop manual tells you to use a special "universal holder" to remove the drive pulley face. Anybody got a workaround?
| Subject: Re: drive belt replacement Thu Sep 23, 2021 9:50 pm | |
| Use an OEM Honda belt. Cheap Chinese ones just don't last. Also use the search function on here to look for instructions on how to make a variator tool to help you with the job. Good luck. |
| Subject: Re: drive belt replacement Thu Sep 23, 2021 11:22 pm | |
| https://www.silverwing600.com/t11742-diy-variator-holding-tool?highlight=DIY+Variator+toolYou can use an impact gun or air ratchet to remove the variator belt but do not use such a tool to replace the bolt. Use the above tool and a proper torque wrench to install the bolt. Using an air ratchet or impact gun may well cause the variator pulley to be installed cockeyed or end up pinching the belt in the variator. Also, the belt gets mounted with the arrows facing the direction of rotation. |
| Subject: Re: drive belt replacement Fri Sep 24, 2021 7:34 am | |
| - dmosemorris wrote:
- Any advice about drive belt replacement. The official shop manual tells you to use a special "universal holder" to remove the drive pulley face. Anybody got a workaround?
I made mine out of 3/4" plywood and appropriate bolts it worked just fine. |
zrx212 Silver Wing Expert
| Subject: Re: drive belt replacement Fri Sep 24, 2021 1:12 pm | |
| This is my homemade/DIY variator and clutch holder tool, I've had this for a long time, it's adjustable, bolts length/size can be changed and/or rearranged for differents scooters, etc. Just to give an idea. |
| Subject: Re: drive belt replacement Fri Sep 24, 2021 1:15 pm | |
| Fancy shmancy nice tool. |
| Subject: Re: drive belt replacement Fri Sep 24, 2021 11:01 pm | |
| Thanks guys, is just stuff/material I had laying around the garage, works good. |
