Latest topics | » Passenger Back rest by landisr Today at 12:02 am
» OE Quality Drive Belt by landisr Wed Oct 16, 2024 6:11 pm
» Mini-Mate Camper by MikeO Wed Oct 16, 2024 12:17 pm
» New to the forum by Dale N. Mon Oct 14, 2024 3:10 am
» Complete Fairing Bolt Kit For silverwing/ worth buying?? by zrx212 Thu Oct 10, 2024 12:41 pm
» New FPR, new vacuum pipes, still 22mpg by steve_h80 Wed Oct 09, 2024 8:18 am
» Gulf shores, AL by Mauryturnsoutitsmine99 Tue Oct 08, 2024 8:52 pm
» Searching for Honda or After Market Part by sonuvabug Tue Oct 08, 2024 5:22 pm
» A strange howl by zrx212 Tue Oct 08, 2024 3:44 pm
» First impressions of the silver wing by RedRaider Tue Oct 08, 2024 1:04 am
| | Replacement Belt | |
| Subject: Replacement Belt Sat May 02, 2009 6:51 pm | |
| Any recommendations on which kind of belt to replace the drive belt with? |
Number of posts : 2453 Location : Georgetown, Tx Points : 8337 Registration date : 2008-12-23
| Subject: Re: Replacement Belt Sat May 02, 2009 9:39 pm | |
| - Hondarider47 wrote:
- Any recommendations on which kind of belt to replace the drive belt with?
Mitsuboshi Kevlar Belthttp://www.scootertrap.com/SilverWing600.htm The OEM belt slaps the top and bottom metal portion of the CVT housing. I have not had any belt slap with the Mitsuboshi Kevlar Belt. |
| | | Guest Guest
| Subject: Replacement Belt Sun May 03, 2009 1:07 am | |
| That is what I have heard also, Thanks. |
| Subject: Re: Replacement Belt Sun May 03, 2009 2:05 am | |
- That is what I have heard also
ScooterTrap says " Reliability and durability is what you'll get from a kevlar belt. Less stretching and less wear than conventional belts." But when asked about quantifying how to compare or quantify better than OEM belt, they could not provide any details or specifics. The only concrete and discernible difference is the belt slap .... it could be a better/stronger belt but there is no proof to compare from either side. |
| | | Guest Guest
| Subject: Re: Replacement Belt Thu May 21, 2009 8:20 am | |
| Kevlar belts ARE stronger than steel belts, assuming the engineering quality is there.
I'd be surprised if the stock belt isn't already Kevlar, though. That seems like a no-brainer these days. But if the "slap" goes away the aftermarket belt must be less prone to stretching.
I do know that when I first bought my 1999 Volkswagen diesel the cam drive belt had a 40,000 mile life expectancy, and field experience among the less mechanically inclined indicated that you could expect failure and engine destruction in less than 50,000 miles. A better belt, either with Kevlar or with MORE Kevlar (we never figured out the exact difference) was developed that raised the change interval to 80,000 miles. Kevlar is the real deal. |
| | | Cornishman Maxi-Scooter Rider
Number of posts : 181 Age : 70 Location : Wiltshire UK Points : 5882 Registration date : 2009-04-04
| Subject: Re: Replacement Belt Thu May 21, 2009 10:28 am | |
| While the subject is open, I've been told that the belt change is so simple and that there is a video on youtube. The only video that I've seen is of a guy squeezing the drum and popping in a spacer on the variator to replace the belt. Took him seconds to do. |
| Subject: Re: Replacement Belt Thu May 21, 2009 3:19 pm | |
| - mickey wrote:
- I'd be surprised if the stock belt isn't already Kevlar, though. That seems like a no-brainer these days. But if the "slap" goes away the aftermarket belt must be less prone to stretching.
I had belt slap on the original OEM belt when it was relatively new (before stretching), which disappeared after enough miles. I have not had any belt slap on the Mitsuboshi Kevlar Belt. I wonder if the Mitsuboshi is either shorter and/or tighter than the OEM belt. |
| Subject: Re: Replacement Belt Thu May 21, 2009 3:25 pm | |
| - Cornishman wrote:
- While the subject is open, I've been told that the belt change is so simple and that there is a video on youtube. The only video that I've seen is of a guy squeezing the drum and popping in a spacer on the variator to replace the belt. Took him seconds to do.
http://silverwing.org/cgi-bin/topic_show.pl?pid=7361#pid7361 Someone did say they changed the belt without removing the nut. I thought it was beneficial to open the variator check and clean the rollers and clean the variator ramps when I changed the belt. |
