| Fuel additives test | |
| Subject: Fuel additives test Thu Oct 07, 2021 7:26 pm | |
| I hope this isn’t opening another can of worms but, for we who are tucking our scoots in for a winter’s nap, here’s a fuel additives test video:
https://www.youtube.com/watch?app=desktop&v=chsGBhB5g7o |
| Subject: Re: Fuel additives test Thu Oct 07, 2021 11:20 pm | |
| I use Seafoam in my gas can for my lawn mower and snow blower. Usually a 6 gallon can of treated gas will last me up to 3 years before I have to fill it up again. When I know I'm done, or maybe on my last ride I run the tank low and fill it up with non-oxygenated 91 octane fuel. We have a station, Kwik Trip, here in Princeton that I take it to for that fill. I also store my SWing in my attached heated garage over the winter. I don't have the heat turned up but the lowest setting on the thermostat is 40 degrees. That's the temp it sits at unless I want to go work in the garage. Then I turn it up to about 65 and go back in the house and have a cup of coffee and let the furnace cycle a couple of times. That way I can work out there in my short sleeve shirt. So far I haven't had any problems with it starting in the spring... Knock On Wood!! |
| | | GHM-PM Site Admin
| Subject: Re: Fuel additives test Fri Oct 08, 2021 7:27 am | |
| I use Sta-bil usually. Sounds like a decent choice but I have used Sea Foam in past. I think I will save that for simply cleaning the gas tank not as a storage additive.
Interesting but very STRANGE video, Tim!!! LOL |
| | | bikehiker Silver Wing Rider
Number of posts : 433 Location : New Cumberland PA Points : 3177 Registration date : 2017-09-07
| Subject: Re: Fuel additives test Fri Oct 08, 2021 4:48 pm | |
| Lesson learned by me TWICE: Store with a FULL tank and no additives. Once I stored with about a half tank because I was running the bike occasionally when I got a weather window. This was a Honda Silver Wing with fuel injection! Never had trouble starting before! But when I got a hard months-long snow/freeze, I neglected to fill the tank, BUT put in an additive (can't remember which, I think Seafoam} Come warmer weather, crank, crank. Day after day Nothing. Battery running low. Replaced plugs and drained tank and replaced with new fuel. Crank, crank. Trailered to Honda service. Just a few more cranks from them (why not me?) and it started. Lesson learned? No. Next winter had tank about 60-70 percent full. Thought that would be enough. Crank, crank. With patience and a li-on booster starting battery, after about two days cranking, It started. Dope slap lesson: Fill tank. |
| | | GHM-PM Site Admin
| Subject: Re: Fuel additives test Fri Oct 08, 2021 9:20 pm | |
| On my Forza before I put it to bed for the winter, I take it for a full tank of fuel and before I fill it, Sta-bil is put in. Then I drive it 5 miles plus to circulate the mixture. No problems so far.
My lawn mower and weedeater are simply run dry and put away!!! |
| Subject: Re: Fuel additives test Fri Oct 08, 2021 9:30 pm | |
| That's one thing my Dad also taught me. Before filling the tank put in whatever additive you are going to use then fill the tank. That mixes them both. |
| Subject: Re: Fuel additives test Sat Oct 09, 2021 8:48 am | |
| - GHM-PM wrote:
- On my Forza before I put it to bed for the winter, I take it for a full tank of fuel and before I fill it, Sta-bil is put in. Then I drive it 5 miles plus to circulate the mixture. No problems so far.
My lawn mower and weedeater are simply run dry and put away!!! The last line, my power washer, BEFORE STORAGE RUN GAS TANK DRY. and empty water pump. With todays crap gas that seems to work. |
