| Help with rear tire (swingarm part) removal | |
+3honda_silver DennisB allhondascoots 7 posters |
allhondascoots Scooter Rider
Number of posts : 48 Age : 61 Location : 62285 So ILL Points : 5437 Registration date : 2010-02-21
| Subject: Help with rear tire (swingarm part) removal Tue Mar 02, 2010 7:35 pm | |
| OK..so I've checked lots of info on here and even scrutinized this :how to" http://www.leroybeal.net/motorcycles/silverwing/articles/rearwheel/rearwheel.html But I've goten everything loose and the swing arm won't slide off the axle. It's loose and I can rock it a bit where it is now unbolted, but it wont slide off the axle shaft. Check out these pics and see if I've forgotten something or is there a trick? I gently tapped on the axle end with a hammer to see if it needed to pop off somehow. but nothing. I even loosened the Torx bolts that didnt need to... HELP. |
| Subject: Re: Help with rear tire (swingarm part) removal Tue Mar 02, 2010 8:31 pm | |
| Looks like you have it ready to be removed. Try tapping with a rubber hammer. TAPPING is the key word here. Should come right off. Try spraying WD-40 on the axle where the spacer was removed from under the large nut. The axle just might have a little rust between the bearing I.D. and the axle O.D. keeping the arm from being removed. |
| Subject: Re: Help with rear tire (swingarm part) removal Tue Mar 02, 2010 8:44 pm | |
| Thanks. I'll give that a try. Just wanted to make sure I wasnt doing something stupid before I start beating and prying on it.....you know so that I can now do something stupid! Maybe I'll let it soak over night. |
| Subject: Re: Help with rear tire (swingarm part) removal Tue Mar 02, 2010 8:54 pm | |
| - allhondascoots wrote:
- OK..so I've checked lots of info on here and even scrutinized this :how to"
I checked your pictures against a PDF I made of the Leroy Beal page with Honda's recommendations merged into notes. It looks like you have everything. Trying to remember from memory ... in the picture above make sure the shock is not sitting on the SWing arm. If you grab the tire and try pulling does it proved any more movement?? |
| Subject: Re: Help with rear tire (swingarm part) removal Tue Mar 02, 2010 9:55 pm | |
| I'm absolutely sure that the shock isn't the problem. Its just resting there in the picture. I'm starting to get PO'd The tire doesnt budge..other than spin. The swing arm will move just a bit, but not off..or in that direction at all, just back and forth....rotation wise about 1/2inch untill the arm makes contact with the rest of the swing arm. I've pulled and wiggled and even used a small slide hammer with a flat hook around the back. I'd swear theres a snap ring or something holding it on. I'm not this stupid in real life |
MOWing Scooter Rider
Number of posts : 30 Age : 57 Location : Columbia, MO Points : 5430 Registration date : 2010-02-10
| Subject: Re: Help with rear tire (swingarm part) removal Wed Mar 03, 2010 12:26 pm | |
| Sounds like the bearing is seized to the shaft. You might try heating the area with a heat gun. Not enough to peel the paint, but enough to heat things up a bit. If you get it off be sure and clean up the axle there where it goes into the bearing.
I am curious as to why you are completely tearing down the bike. In another post you have pictures of parts all over the place. |
| Subject: Re: Help with rear tire (swingarm part) removal Wed Mar 03, 2010 1:12 pm | |
| - MOWing wrote:
- Sounds like the bearing is seized to the shaft. You might try heating the area with a heat gun. Not enough to peel the paint, but enough to heat things up a bit. If you get it off be sure and clean up the axle there where it goes into the bearing.
I am curious as to why you are completely tearing down the bike. In another post you have pictures of parts all over the place. Thanks. I'll give that a try. To replace this piece: Almost all the plastic needs to be removed. I took the back parts off so I could remove an improperly installed hard case. And just to check it all over and give a cleaning from the inside out. |
| Subject: Re: Help with rear tire (swingarm part) removal Wed Mar 03, 2010 2:45 pm | |
A 3 or 4 arm gear puller might be a safer option. |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 6177 Registration date : 2009-03-24
| Subject: Re: Help with rear tire (swingarm part) removal Wed Mar 03, 2010 3:25 pm | |
| I agree with Bill, you don't want to damage the splines. The first time I removed my rear wheel it was stuck on pretty good. Before reinstalling, the manual mentions to grease the splines. |
| Subject: Re: Help with rear tire (swingarm part) removal Thu Mar 04, 2010 12:24 am | |
| One of the best things you can use on drive line splines is moly paste. Honda sells the stuff, 'Honda 60'. The Goldwing manual calls for it on all the splines in the big Wing's drive system. The advantage of moly paste is that even when the grease carrier is gone the molybdenum will still provide protection for the splines against wear. The stuff isn't cheap but will really keep the splines in like new condition. The ones on my '93 GW with 134,000 miles still fit as snug as new. The stuff you want isn't the moly grease they sell in auto parts stores but Moly Paste of 60% or more Molybdenum content. Loctite also makes the stuff. |
| Subject: Re: Help with rear tire (swingarm part) removal Thu Mar 04, 2010 10:37 am | |
| Got it!Thanks honda-silver, the gear puller did the trick! It took a bit of manipulation to get it to line up with the axle while still maintaining a good grip on the arm. Cranked it down with hand pressure on the tools T handle until very snug, then tapped on the arm with a mallet. Turned the handle another turn...more mallet tapping...repeated this about 5 times until it slid right off..no popping or anything dramatic. Looks like it'll clean up and with a new coat of grease, should be fine. I really appreciate the input! Now to get the tire off the rim.... |
| Subject: Re: Help with rear tire (swingarm part) removal Thu Mar 04, 2010 3:11 pm | |
| - exavid wrote:
- One of the best things you can use on drive line splines is moly paste. Honda sells the stuff, 'Honda 60'. The Goldwing manual calls for it on all the splines in the big Wing's drive system. The advantage of moly paste is that even when the grease carrier is gone the molybdenum will still provide protection for the splines against wear. The stuff isn't cheap but will really keep the splines in like new condition. The ones on my '93 GW with 134,000 miles still fit as snug as new. The stuff you want isn't the moly grease they sell in auto parts stores but Moly Paste of 60% or more Molybdenum content. Loctite also makes the stuff.
I used Mobil 1 Synthetic Grease ( http://www.mobil.com/canada-english/lubes/pds/iocaenpvlmomobil_1_synthetic_grease.asp ). It would be interesting how to compare these two. |
| Subject: Re: Help with rear tire (swingarm part) removal Thu Mar 04, 2010 3:14 pm | |
- Got it!
That is great news. - allhondascoots wrote:
- Looks like it'll clean up and with a new coat of grease, should be fine.
Why did it stick in the first place?? |
| Subject: Re: Help with rear tire (swingarm part) removal Thu Mar 04, 2010 3:37 pm | |
| - honda_silver wrote:
Why did it stick in the first place?? Good question. Honestly, I didnt get a chance to mess with it until after work at 9 last night, and was so happy it came off with only a few minutes of work, that I only took a glance at the shaft and bearing and it didnt look that bad. Some whitish oxidation on the shaft. I'll post a pic tonight before cleaning it up. |
| Subject: Re: Help with rear tire (swingarm part) removal Fri Mar 05, 2010 11:15 am | |
| Subject: Re: Help with rear tire (swingarm part) removal Fri Mar 05, 2010 11:39 am | |
This needs a good cleaning ... and lots of grease. - allhondascoots wrote:
This looks like it needs to be replaced. |
| Subject: Re: Help with rear tire (swingarm part) removal Fri Mar 05, 2010 11:46 am | |
| That difinitely looks like water intrusion. Not rust, but water oxidation. Some one must have used a power spray washer on the wheels at some time in the past. You might think about replacing the bearring at this point to be on the safe side. Some very fine steal wool and WD-40 will remove it off the axel. Not to much...just a little scrubing, that's all. Then grease it well when you reasemble it. You might want to remove the front wheel at this time and check it out to see if water got into that axel as well. |
| Subject: Re: Help with rear tire (swingarm part) removal Fri Mar 05, 2010 11:56 am | |
| Thanks for the heads up. I'll look it over carefully, and the front is off already with no problems.. After I clean it up, I'll get a professional opinion here at work before putting it back together. |
| Subject: Re: Help with rear tire (swingarm part) removal Sun Mar 07, 2010 2:23 pm | |
| Remind me to never change my own tires again. It was much harder (and dirtier) than it looks, even with the right spoons/irons. Got the tires mounted and installed and the bike mostly back together. As far as the seized swing arm, the bearing cleaned up and felt fine, but the axle shaft itself was pitted and kinda rough. I used a bit of emery cloth to smooth out the high spots, cleaned it all up, recoated it all in a bit of grease and it slid right into place with no problem. Of couse it all might fly apart or break off at 60 mph...... No, I'm sure it'll be fine. Thanks again for the helpful info guys. |
| Subject: Re: Help with rear tire (swingarm part) removal Sun Mar 07, 2010 4:39 pm | |
- Remind me to never change my own tires again.
It was much harder (and dirtier) than it looks, even with the right spoons/irons. That is why I have my own NoMar Cyclehill tire changer. |
john123 Maxi-Scooter Rider
Number of posts : 133 Age : 76 Location : Santa Barbara California Points : 5563 Registration date : 2010-02-21
| Subject: Re: Help with rear tire (swingarm part) removal Wed Mar 17, 2010 9:22 pm | |
| Oh my gosh! With all that information and my head is spinning. The pictures and all the informative information regarding wheel removal and oil types is fantastic. I do use straight synthetic (amsoil 10-30) but now realize I should be using a higher grade. I don't need a tire replacement at this time but will soon and I am glad to have all this information at hand. Thanks to all for the GRATE information. |
