n7188u Scooter Rider
Number of posts : 23 Location : Port Orange, FL Points : 4339 Registration date : 2013-02-07
| Subject: Swingarm seal removal Wed Jul 06, 2022 1:10 pm | |
| Hello Forum Members,
I need some advice at possible tip. After great effort I finally removed the right swingarm on my 2005 Silverwing for tire replacement. What a job that was as the bearing was seized on the shaft due to corrosion.
I want to change the seals to prevent this in the future. the inner one was easy as it is flush. The outer one is inside the bore where the shaft nut is located and much harder to pull out. Any hints on tool or technique to get this seal out?
Thanks, Chris |
| Subject: Re: Swingarm seal removal Wed Jul 06, 2022 3:06 pm | |
| IIRC There is a snap ring holding that outer seal in place. I think. So remove the snap ring and you should be able to pry out the seal with a screwdriver. Or remove the inner seal and drive out the outer seal from the inside.
But however you accomplish the removal, DO NOT lose the collar which fits into the outer seal. |
| Subject: Re: Swingarm seal removal Wed Jul 06, 2022 4:54 pm | |
| Thanks for the reply Tim. I will look closer but I didn't see a snap ring holding the outer seal. I did see one holding the bearing, which I intent to remove to verify that the bearing is still fully seated (a LOT of force was needed to remove the swingarm from the shaft).
I did remove the inner seal and tried to push the outer out but not much to push against (at least not sure if what I feel as a step to push against is the seal itself or a lip in the swingarm). Will continue to look and see how to do this. As it is usually the case, I am sure there is a way but doesn't look easy.
The inner one came out very easy with a screwdriver (heresy) without scratching anything.
Thanks for the heads up on the collar. I will look for that and make sure it is safe.
Chris |
zrx212 Silver Wing Expert
| Subject: Re: Swingarm seal removal Wed Jul 06, 2022 7:09 pm | |
| Both seals are just pushed in, they are just dust seals, there's a snap ring that holds the bearing in place on the inside/back side you should see once the inner seal is removed, the bearing itself is double sealed and pre-lubed for life, if it spins freely leave it alone, be careful not to damage bearing seals, the dust seals rarely fail, the bearing or bushings got stuck/corroded on shaft because lack of lube, you may have to polish the wheel shaft and interior of bushings and bearing with green scotch-brite to remove surface corrosion or grime, remove the outer bushing #7 and smear some grease in cavity, ditto for inside if seal still usable ?, all the parts that are metal to metal contact should have a light coat of grease or anti-seize compound, the splines on wheel and shaft should be coated with a light coat anti seize or grease, waterproof/marine grease works good.
Here's a link where you can see the layout and buy parts if needed. ?
Non ABS 2005 https://www.ronayers.com/oemparts/a/hon/5053f29af870021c54be6b8f/rear-wheel
ABS 2005 https://www.ronayers.com/oemparts/a/hon/5053f295f870021c54be6b53/rear-wheel |
| Subject: Re: Swingarm seal removal Thu Jul 07, 2022 9:14 am | |
| Thanks again for the feedback.
A little perseverance paid off (as always). I finally found one of those tools used to open paint cans, which have the perfect hooky end, I slid it in from the bearing side and tapped/pushed the seal out. it was easy once the right tool was found.
I decided to replace both seals. They may have been OK but the inner one was abused a little during the swingarm removal process and I figure that with the bike being almost 20 years old might as well replace anything I can made out of rubber.
So the rebuild continues and I may tap into the forums knowledge base if more questions arise.
Thanks, Chris |
