Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby JohnyC Today at 5:39 am
Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby JohnyC Yesterday at 10:04 am
Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
cello33
Number of posts : 150
Registration date : 2018-07-09
Front Brake Caliper Interchangeability Non Abs / ABS Empty
PostSubject: Front Brake Caliper Interchangeability Non Abs / ABS   Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeMon Apr 04, 2022 7:26 pm
Hi Swingers!
Any idea if the front brake caliper can be swapped between the non-ABS and ABS model?
My belief is that it can as the only difference is the mounting bracket , looking at parts sites though the sliding pins look to be at different places on the ABS one suggesting the caliper is longer/ bigger then the non-abs one ? Any ideas.....TIA
PostSubject: Re: Front Brake Caliper Interchangeability Non Abs / ABS   Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeMon Apr 04, 2022 8:10 pm
It doesn’t look like they are interchangeable. But you might email Siataukreg / Ronald Davies Cox about it. He more than likely has a couple of each version in his shed.
kitchenman
Registration date : 2019-10-14
PostSubject: Re: Front Brake Caliper Interchangeability Non Abs / ABS   Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeThu Apr 07, 2022 5:52 am
Hi, I spoke to Ron Cox Davies about this a while ago, I had a problem fitting a 2004 wheel to my 2002, The calliper would not fit, the 2004 disk is a larger diameter he said the callipers are the same but the mounting brackets are different, the sliders do look different
http://kitchenman.co.uk
cello33
PostSubject: Re: Front Brake Caliper Interchangeability Non Abs / ABS   Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeThu Apr 07, 2022 12:54 pm
Thks , I should know soon as I have ordered a 04 disc and caliper all scondhand.
I had problems removing the pistons from my caliper as it looked like i would need to split the caliper to have the clearance to remove the pistons. THought I would recondition a second caliper and then just swap it out.
cheers swingers
cello33
PostSubject: Re: Front Brake Caliper Interchangeability Non Abs / ABS   Front Brake Caliper Interchangeability Non Abs / ABS I_icon_minitimeFri Apr 22, 2022 7:08 pm
You were right by the way , even using the later caliper carrier the larger disk on the ABS model binds on the caliper. It appears the 04 and later fork has a offset for the top mounting point that clears the larger disk.
Worth a try but alas no cigar ......
» Brake Caliper Grease
» rear brake caliper stuck?
» Front brake caliper bolt torque
» 06 Honda SW rear brake caliper
