Rear Brake caliper / Parking Brake I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Rear Brake caliper / Parking Brake I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Rear Brake caliper / Parking Brake I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Rear Brake caliper / Parking Brake I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Rear Brake caliper / Parking Brake I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Rear Brake caliper / Parking Brake I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Rear Brake caliper / Parking Brake I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Rear Brake caliper / Parking Brake I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Rear Brake caliper / Parking Brake I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Rear Brake caliper / Parking Brake I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
micbusathens
bikerboy
NWSSC
badaboum
11 posters
badaboum
badaboum
Number of posts : 58
Registration date : 2013-05-23
Rear Brake caliper / Parking Brake Empty
PostSubject: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 4:29 am
Guys,
I have a 2009 SWT.
The braking system is exactly the same as the Silverwing sold in the US.
I bought it second hand and I was trying this week to have a closer look at both my rear brake pad and the parking brake pad.
I tried to remove them and the fasterner holding the pad/calider (a 5.5 BTR) seems to ''glued''
Impossible to remove it.
A quick call to Honda, and the guy told me that those bolts are always mounted with a special ''grease'' to avoid them to ''solder''
A couple of question here:
1) Can you confirm the BTR is 5.5mm not 5mm?
I have found contradective information on the internet and the Shop manual that I have is in Italian (not easy for a French to understand)
2) Are you aware of that ''special grease?
3) What do you advise me to do? heating all the caliper?
4) Any idea where i can have a ''cheap'' copy (PDF or not) of the service manual of the Silverwing?
I beleive in terms of mecanics it is the same as the SWT and not need to look out for months for the SWT one in English..
Thanks for your help
badaboum
badaboum
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 4:34 am
Here is a picture seen on a French website that says that the Allen is 5.5
Rear Brake caliper / Parking Brake 337853IMG20130203114420
Number of posts : 757
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 8:19 am
Bonjour Badaboum. A mon avis , le 5.5 n'existe pas aux Etats Unis, ni au Canada. Jamais recontre ici. La graisse speciale dont vous parlez serait peut-etre ce qu'on appelle Loctite. Ca empeche le boulon de se defiler tout seul avec la vibration. J'ai recontre le meme probleme avec mon Honda ACE. La rouille qui forme dans les sillures "soude" le boulon et la piece. Si vous avec du WD40, ou quelque produit qui chasse l'eau et penetre profondement , ca pourrair defaire la rouille et lacher. Vous pouvez aussi chauffer avec beaucoup de precaution. Si vous avec le machin qui donne des chocs en defillant, " impact gun" ca pourrait aussi marcher. Sinon, le pire c'est d'enlever avec un extracteur, et remplacer le "5" avec un nouveau.
Bonne chance.
badaboum
badaboum
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 9:13 am
Hello
Thanks for the reply (we keep up writing in English or switch to French?)
What does the Silverwing manuals says about this Allen Wrench? 5 or 5.5 ?
Does the manual says anything about locklite or the Honda mechanics was wrong?
NWSSC
NWSSC
Number of posts : 418
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 11:01 am
If I may suggest, If one wants to receive the benefits of this site(and others) they use the language that it was started in.You can use PM if you wish to.
bikerboy
Number of posts : 405
PostSubject: Rear brake caliper   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 11:34 am
The bolts holding the caliper on my SWing are 8mm x 1.25pitch. The manual says to replace (hence I have a nice new one to measure) but my techy said to just top up the threadlock. I can't help with the parking brake as I haven't a spare for that and it's a bit parky in the garage for grovelling on the concrete !
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 11:50 am
The brake pad pin on my 2003 FSC600 here in the US is 5mm, and we do use a high temperature grease on those pins (and the thread) so that the brake pads slide easier and so that the threads do not seize in the caliper body.
I'd clean that area then remove the rubber plug and try the 5.5MM hex tool. If that doesn't fit easily then drop down to a 5MM.
Once you determine which is the correct tool size you could cut off a small piece of that tool, insert it in the pin then use a small hammer to hit the tool end as you are turning the tool with a wrench --kind of like an impact tool. HTH
Number of posts : 921
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 12:04 pm
I have just replaced the Parking brake pads, i didn't have any trouble taking the pad pins out. I have also replaced the rear brake pads in the last year , again i had no problems taking the bolts or the pins out. I have the A7 now, six year old Silverwing. Possibly your model is different but , i wouldn't have thought so.Smile
badaboum
badaboum
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 12:12 pm
ok thanks for that
I will pass on the message to my mechanics.
micbusathens
micbusathens
Number of posts : 199
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeMon Nov 25, 2013 4:05 pm
....and correct grease is.. copper anti seize grease
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeTue Nov 26, 2013 8:50 pm
I apologise for the posting in French. I think that the other members have given more valuable technical information. All I said was that I have never encountered a 5.5 Allen key in Canada. Rust is probably the cause of the stuck pin, and penetrating oil or WD 40 and heat would probably loosen it. An extraction would probably be a last resort, requiring a new bolt.
Number of posts : 2387
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeTue Nov 26, 2013 9:51 pm
You haven't looked very hard Smile
lalee
Number of posts : 289
Registration date : 2013-11-09
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeTue Nov 26, 2013 10:36 pm
I think the French version was much more fascinating. I didn't understand a word of it, but it sparked my imagination. guitarist
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeWed Nov 27, 2013 7:50 am
Bigbird, my apologies. I sit corrected, and will look for the 5.5 mm Hex key. May come in handy sometimes. Thanks.
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeWed Nov 27, 2013 12:36 pm
Lalee, are you, or were you "Larry from Seattle"? Your posts and replies remind me very much of him, and he rode a Goldwing.Smile
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeWed Nov 27, 2013 1:17 pm
You're right. That is him!
Look at his avatar. I wonder if he'll start trolling on me again. I hope not.
lalee
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeThu Nov 28, 2013 7:41 am
We think quite a bit alike. I am also riding this bike as well:
Rear Brake caliper / Parking Brake Bikeandtrailer_zps84f60406
Number of posts : 4218
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeThu Nov 28, 2013 7:55 am
Why not answer the question Larry, all larryfromseatle's photos are still here for anyone to view and your avatar photo riding the Gold Wing with the red Coleman cooler box on the back is taken from there. In fact the same red cooler box is on the photo you've just posted above.
Happy Thanksgiving.  Smile
Colin B
Colin B
Number of posts : 586
Registration date : 2013-03-20
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeThu Nov 28, 2013 1:08 pm
Admin hat on.
For the record, all indications (including some that members can't see) suggest that Larry and lalee are one and the same.
I believe that there has been "friction" in the past. That pre-dates me, so I will judge only what I read from now on. If I see any "trouble" brewing, I will step on it.
Admin hat off .... Back to the topic.
lalee
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeThu Nov 28, 2013 1:33 pm
Well none of this has anything to do with the OP, and I apologize to all who have no interest in who I am and only interested in the original conversation.
My intro has been updated.
Happy Thanksgiving to all.
PostSubject: Re: Rear Brake caliper / Parking Brake   Rear Brake caliper / Parking Brake I_icon_minitimeThu Nov 28, 2013 2:08 pm
Thankyou Colin B. I was not trying to cause any upset. I was just curious.Smile
» Rear disc brake caliper
» 06 Honda SW rear brake caliper
» Rear Brake Caliper Cleaning
» rear brake caliper stuck?
» How to: Remove Honda Silver Wing REAR BRAKE CALIPER.(Youtube)
Honda Silver Wing Scooter Forum :: Other Scooters and Motorcycles :: Honda SWT400/SWT600-
