coolant leak? and shutter/lugging of engine I_icon_minitimeby JohnyC Today at 5:39 am
coolant leak? and shutter/lugging of engine I_icon_minitimeby JohnyC Yesterday at 10:04 am
coolant leak? and shutter/lugging of engine I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
coolant leak? and shutter/lugging of engine I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
coolant leak? and shutter/lugging of engine I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
coolant leak? and shutter/lugging of engine I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
coolant leak? and shutter/lugging of engine I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
coolant leak? and shutter/lugging of engine I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
coolant leak? and shutter/lugging of engine I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
coolant leak? and shutter/lugging of engine I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
3 posters
Cannavis
Number of posts : 5
Registration date : 2022-07-01
coolant leak? and shutter/lugging of engine Empty
PostSubject: coolant leak? and shutter/lugging of engine   coolant leak? and shutter/lugging of engine I_icon_minitimeTue Jul 05, 2022 9:00 pm
Just got a thristy 03', ripped on it home and double checked the oil (when I looked at the bike its seemed to be way overfilled)
Sure enough it was about a 1/4 inch above the top fill line.
Did the oil change
Did a full coolant flush and refill (engine ice)
I do have what feels like a shutter/lugging feeling at 40-55mph only why cruising, no shutter or lug feeling when accelerating through that speed. Is this just a normal feeling or should I be looking into a possibly known issue?
Also with filling the coolant I filled the rad/fill port and the reservoir to the middle. Today at work I noticed a stream of coolant coming from the SW that showed that it had been leaking gradually (prob as the day warmed up I am in AZ). I took it home and when I got home the fan kicked on (I go 25 mph in my neighborhood). When I stopped I had quite the mess of coolant. I took the plastics off to find out where the leak was coming from it came from the coolant over fill line.... That confused me as the res is still at the same mark as before and not full.... any tips?
If this is in the wrong spot I apologize rather new here
any help will be massively appreciated
Thx Cannavis
Number of posts : 580
PostSubject: Re: coolant leak? and shutter/lugging of engine   coolant leak? and shutter/lugging of engine I_icon_minitimeWed Jul 06, 2022 7:31 am
" I do have what feels like a shutter/lugging feeling at 40-55mph only why cruising, no shutter or lug feeling when accelerating through that speed. Is this just a normal feeling or should I be looking into a possibly known issue? "
The SW600 long cvt drive belt will cause harmonic vibration and sometimes belt slaps the cvt case aka "Belt Slap", mostly with higher mileage or aged belts, not a real concern issue, kinda nature of the beast, a fresh belt and rollers helps sometimes, but a full cvt service, including disassembly clean and lube of rear pulley is best.
Dr. Pulley 26gr sliders also helps overall performance. IMO the best fix is the Malossi white torque spring alone (harder to install, but similar effect to sliders, cheaper mod !!). You can do either or both (best), the spring has worked great for me with stock rollers.
They are all kind of remedies you will still feel a little belt shudder regardless, use the search function for all the mods and services, plenty of post on it.
Cannavis
Number of posts : 5
PostSubject: Re: coolant leak? and shutter/lugging of engine   coolant leak? and shutter/lugging of engine I_icon_minitimeWed Jul 06, 2022 10:54 pm
thanks @zrx212!
I did not opt to ride the SW today so she sat in the garage and when i got home i had a puddle of coolant (from the overflow) sitting on the floor... still rather confused on the coolant leak
Cannavis
Number of posts : 5
PostSubject: Re: coolant leak? and shutter/lugging of engine   coolant leak? and shutter/lugging of engine I_icon_minitimeThu Jul 07, 2022 7:49 pm
I think i might have installed the res hoses backwards as the overflow leaks when the bike is on and the reservoir is not full.
Any opinions?
Number of posts : 403
PostSubject: Re: coolant leak? and shutter/lugging of engine   coolant leak? and shutter/lugging of engine I_icon_minitimeThu Jul 07, 2022 9:30 pm
The two hoses to the reservoir are the overflow (from the top) and the siphon hose (connecting to the bottom). If you swapped these the siphon hose will allow air to be sucked back into the radiator  and the overflow would empty the reservoir immediately; I would have thought that would be pretty obvious when you refilled the reservoir.
You may have a problem with the radiator cap not holding pressure; if that happens the coolant in the engine can boil at a lower temperature and the steam released can burp coolant out of the reservoir. You did mention the fan coming on, which might indicate the engine running hotter than usual?
When I changed coolant on my Swing, I had a devil of a time getting air out of the system. I followed the manual, and still had to run the engine with the cap off for quite a while before the level stabilsed. I have never had a similar issue on any of my many water-cooled Honda motorcycles.
Cannavis
Number of posts : 5
PostSubject: Re: coolant leak? and shutter/lugging of engine   coolant leak? and shutter/lugging of engine I_icon_minitimeSat Jul 09, 2022 11:34 pm
I don't want to say you are incorrect on your first statement but I did have the hoses swapped and it only dripped a few mil per day (even with a 300 mile ride).
I swapped them and no leak now. It does have the fan kick on when idling or riding slowly (I live in AZ).
after swapping the hoses no more leaks and no high temps
When I did the flush I kept the cap off and did extensive revs till the coolant was no longer being sucked down.
» Coolant leak
» coolant leak
» The dreadful coolant leak
» New Silver Wing Owner
» Engine oil leak
