| The dreadful coolant leak | |
tankyuong Silver Wing Rider
Number of posts : 475 Age : 49 Location : Missouri Points : 6300 Registration date : 2009-07-12
| Subject: The dreadful coolant leak Thu Oct 11, 2012 12:06 pm | |
| I got a small drop on the garage floor,opened both sides of the skirts and still can't find the location except for on the bottom of the right plastics,wiped it down and the next day, another drop .must be coming from the upper part . |
Number of posts : 4415 Age : 81 Location : damn near Philadelphia, PA Points : 10747 Registration date : 2009-06-12
| Subject: Re: The dreadful coolant leak Thu Oct 11, 2012 4:09 pm | |
| - tankyuong wrote:
- I got a small drop on the garage floor,opened both sides of the skirts and still can't find the location except for on the bottom of the right plastics,wiped it down and the next day, another drop .must be coming from the upper part .
Check the hose clamps on the water pump hoses. Even though the pump is on the left side the coolant could possibly migrate to the opposite side. I've had coolant drips from the various hoses in the past that have been remedied by tightening the clamps and presently have a small amount of coolant dripping from the weep hole in the water pump. Even though I picked up a new pump, but it's not serious enough to warrant tearing things apart right now. Eventually I'll get round to changing it. |
| | | kbcmdba Maxi-Scooter Rider
Number of posts : 178 Location : Tennessee, US Points : 5150 Registration date : 2011-05-05
| Subject: Re: The dreadful coolant leak Fri Oct 12, 2012 12:54 am | |
| Had a similar problem but mine was my front fork seals. If you can park it on a long sheet of paper, finding the source may be easier. Don't forget that fluids will often travel sideways down body parts... Good luck
| Subject: Re: The dreadful coolant leak Fri Oct 12, 2012 2:18 pm | |
Thanks found it, lower radiator clamp was loose Check the hose clamps on the water pump hoses. Even though the pump is on the left side the coolant could possibly migrate to the opposite side.
Number of posts : 1995 Age : 77 Location : Huntsville, AL Points : 7884 Registration date : 2008-12-24
| Subject: Re: The dreadful coolant leak Fri Oct 12, 2012 2:25 pm | |
Thanks found it, lower radiator clamp was loose. Check the hose clamps on the water pump hoses. Even though the pump is on the left side the coolant could possibly migrate to the opposite side.
I've had coolant drips from the various hoses in the past that have been remedied by tightening the clamps and presently have a small amount of coolant dripping from the weep hole in the water pump. Even though I picked up a new pump, but it's not serious enough to warrant tearing things apart right now. Eventually I'll get round to changing it. I think I found the response. Took me a little bit, but then I'm not really all that good at interpreting the responses of the masses. I hated those "Where's Waldo" books. Dang hidden messages on Beatles albums drove me nuts. What prize do I win? |
| Subject: Re: The dreadful coolant leak Sat Oct 13, 2012 11:38 pm | |
What prize do I win? The knowledge of being right? |
| Subject: Re: The dreadful coolant leak Sat Oct 13, 2012 11:39 pm | |
