Need help with flashing FI code I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Need help with flashing FI code I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Need help with flashing FI code I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Need help with flashing FI code I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Need help with flashing FI code I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Need help with flashing FI code I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Need help with flashing FI code I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Need help with flashing FI code I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Need help with flashing FI code I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Need help with flashing FI code I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
4 posters
Sonnyle
Number of posts : 6
Registration date : 2022-07-29
Need help with flashing FI code Empty
PostSubject: Need help with flashing FI code   Need help with flashing FI code I_icon_minitimeSat Jul 30, 2022 7:03 am
Hello everyone! New member here from Asheville, NC, close to the beautiful Blue Ridge Parkway! I just purchased a 2007 Silverwing 600 with 771 miles on it - yes, hard to believe the mileage! When I turn it on, there is no flashing F1 light. When I let it idle, there is no light. When I start riding it, after a few seconds the f1 light starts giving two short flashes, then stops. Another two short flashes, then stops. I cannot find any information on how to fix this problem. Could you please let me know what are my next steps to resolve this issue? Thank you very much! I will post photos of the scooter in a short while!
Number of posts : 381
PostSubject: Re: Need help with flashing FI code   Need help with flashing FI code I_icon_minitimeSat Jul 30, 2022 8:20 am
Need help with flashing FI code 86023510
Need help with flashing FI code 66800010
^^These are from the shop manual- my manual specifically is for the 2002-03 models, but I would assume they didn’t change the FI system in the scooter.
PostSubject: Re: Need help with flashing FI code   Need help with flashing FI code I_icon_minitimeSat Jul 30, 2022 8:22 am
There’s an online version of the shop manual- let me see if I can find the link to it (I had that then got the paper manual for ease of searching).
Edit: here is the link from this website that takes you to a Google Drive link and you open the manual there:
https://www.silverwing600.com/t12515-service-manual-parts-manual-wiring-diagram-etc-pdf
Looks like 2 flashes is either faulty MAP sensor or poor connection to the MAP sensor vacuum tube.
Number of posts : 580
PostSubject: Re: Need help with flashing FI code   Need help with flashing FI code I_icon_minitimeSat Jul 30, 2022 12:47 pm
Gain access to throttle body (remove under seat cover page 2-5 of SM) and check and/or replace vacuum hoses to map sensor, check and clean map connector 1st. It reads like a bad contact or intermittent map operation.
BTW the fuses boxes slide up after you press retaining tab, slide wiring thru cutout in plastic, etc., be gentle!!
Need help with flashing FI code Screen14
Number of posts : 1384
PostSubject: Re: Need help with flashing FI code   Need help with flashing FI code I_icon_minitimeSat Jul 30, 2022 8:59 pm
1 blink an electrical fault in MAP 2 blinks could still be MAP sensor or a vacuum leak. Map vacuum lines on intake side behind throttle bodies I'll bet something chewed or line cracked. Old school Honda MAP sensors are robust and rarely fail.
» PGM-FI code
» ABS Light Flashing / ABS Not Working
» Paint Code
» Wiring Code Help, Please
» Early V belt flashing light
