| ABS Light Flashing / ABS Not Working | |
eggster34 Scooter Rider
Number of posts : 21 Points : 5661 Registration date : 2009-06-24
| Subject: ABS Light Flashing / ABS Not Working Mon Mar 08, 2010 9:31 am | |
| Hi there, I have a '04 silverwing with 12.000 miles (just had a service where the brake fluid, air filter, spark plugs etc. were changed etc.) 10-15 miles after the service the ABS light started blinking and the ABS system stopped working. The stealership says they need to change the ABS ECU , but I'm sure it's something much more simpler than this. Has anyone experienced the same issue? What would be your suggestions to diagnose the cause of the problem? |
| Subject: Re: ABS Light Flashing / ABS Not Working Mon Mar 08, 2010 10:14 am | |
| Chances are 9 out of 10 that they didn't bleed the brakes completely / fully / correctly (delete as appropriate). And/or they've gotten brake fluid on the rotor. If that does end up being the issue then it's time to change to a dealer that actually knows what they're doing. Ya really don't want some dick-fingered wrench fooling with your ride --"Gol-ly, always wanted t'fix me one-a them scooter thangs". |
jdeereanton Silver Wing Guru
| Subject: Re: ABS Light Flashing / ABS Not Working Mon Mar 08, 2010 4:39 pm | |
| My "guess" - a failure to properly bleed the brakes. That "guess" does not preclude the ABS ECU could have failed, it just seems more likely that they did not do a proper bleeding of the brakes.
Now then, some shops do not do a full brake fluid replacement. Some shops will just siphon out the fluid in the reservoirs and then refill. Not a very kind way to do the task, but it happens.
However, I have not experienced this problem and am truly not familiar. |
DickO Founding Member
| Subject: Re: ABS Light Flashing / ABS Not Working Tue Mar 09, 2010 1:49 am | |
| Not really sure. Surely the dealer can double-check their own work to find out. Either that, or find someone (maybe yourself) to do a quick brake system bleed; which should eliminate that aspect. I'd think if the system operated ok for awhile, then failed, that the ECU could also be a plausible cause. But do the simple stuff first. And "CJ"... could we watch the salty phrases ? ? ? I'm no prude but this is hardly the place for such things. |
thomphoto Maxi-Scooter Rider
Number of posts : 188 Age : 87 Location : Owensboro, Kentucky Points : 5877 Registration date : 2009-06-11
| Subject: Re: ABS Light Flashing / ABS Not Working Tue Mar 09, 2010 8:19 am | |
| (Ya really don't want some dick-fingered wrench fooling with your ride --"Gol-ly, always wanted t'fix me one-a them scooter thangs".)
I love that description. |
| Subject: Re: ABS Light Flashing / ABS Not Working Tue Mar 09, 2010 10:40 am | |
| - DickO wrote:
And "CJ"... could we watch the salty phrases ? ? ? I'm no prude but this is hardly the place for such things. Point taken DickO. Sorry if you were offended. Tim |
| Subject: Re: ABS Light Flashing / ABS Not Working Wed Mar 10, 2010 12:08 am | |
| - eggster34 wrote:
- Hi there, I have a '04 silverwing with 12.000 miles (just had a service where the brake fluid, air filter, spark plugs etc. were changed etc.)
10-15 miles after the service the ABS light started blinking and the ABS system stopped working. The stealership says they need to change the ABS ECU , but I'm sure it's something much more simpler than this. Has anyone experienced the same issue? What would be your suggestions to diagnose the cause of the problem? I just ordered my stainless steel speed bleeders from http://speedbleeder.zoovy.com/category/stainlesssteel. There is a non-stainless steel version which is cheaper. 3 - SB8125L Stainless Steel speed bleeders 1 - Speed Bleeder Bag & Hose Combo 1 - Sealant ( http://speedbleeder.zoovy.com/category ) It may help quickly remove any air bubbles from the system and make it much easier for you to change yourself in the future. |
| Subject: Re: ABS Light Flashing / ABS Not Working Wed Mar 10, 2010 12:32 am | |
| Thanks "CJ"... that was very kind response. |
| Subject: Re: ABS Light Flashing / ABS Not Working Wed Mar 24, 2010 11:13 pm | |
| the issue was with the abs sensor on the front wheel, I got it fixed pretty quickly and everything's back to normal. thanks! |
| Subject: Re: ABS Light Flashing / ABS Not Working Thu Mar 25, 2010 5:18 am | |
| Told you I had no real clue.
Glad it was a quick fix. |
| Subject: Re: ABS Light Flashing / ABS Not Working Thu Mar 25, 2010 8:28 am | |
| - eggster34 wrote:
- the issue was with the abs sensor on the front wheel, I got it fixed pretty quickly and everything's back to normal.!
Thanks for letting us know ... I am sure that this will help someone in the future. Was the ABS sensor "bumped" during service or was the front wheel removed? |
| Subject: Re: ABS Light Flashing / ABS Not Working Sun Apr 25, 2010 9:35 pm | |
| neither, I'd ridden it for a while after service and everything was ok, then I didn't ride the bike for a few days and then the next time I got on it the abs light lit up so I'm not sure what caused it |
