Piotr_Poland Scooter Rider
Number of posts : 29 Age : 58 Location : kraków Points : 3916 Registration date : 2014-03-15
| Subject: Brake light...but working non stop Fri Aug 02, 2024 11:47 am | |
| Hi guys. Weird situation, my brake lights are on immediately I switch on the ignition. I was disconnecting switches on brake levers but no change. Connecting, disconnecting no change...brake lights still on. Engine starts normally. Of course when i disconnect and try to run the engine wont start.To be honest have no idea where to looking for because was easier when no brake lights. |
zrx212 Silver Wing Expert
Number of posts : 566 Age : 65 Location : Ocala, FL Points : 1980 Registration date : 2020-12-26
| Subject: Re: Brake light...but working non stop Fri Aug 02, 2024 2:45 pm | |
| The brake light circuit on the SW600 has no interactions with the start/crank circuit, you must have the wires on the LH brake lever switches mixed up, the switches with connectors facing to center of scooter are for brake lights, the one facing aft only on LH handlebar is your starter "Limit Switch", check this diagram and make sure correct wires are connected, etc. Wires on RH+LH brake switches should be same colors. |
| Subject: Re: Brake light...but working non stop Fri Aug 02, 2024 3:05 pm | |
| Subject: Re: Brake light...but working non stop Sat Aug 03, 2024 4:18 am | |
