| | brake light | |
hondapete Scooter Rider
Number of posts : 35 Location : west wales Points : 1297 Registration date : 2021-04-25
| Subject: brake light Tue Jul 30, 2024 1:16 pm | |
| i have a problem with no brake lights so i changed the bulb anyway and ran the bike for a minute at the most with the bulb holder removed. still no brake light, only tail light lit, but the bulb is literally too hot to touch. is this normal? |
Number of posts : 554 Age : 65 Location : Ocala, FL Points : 1931 Registration date : 2020-12-26
| Subject: Re: brake light Tue Jul 30, 2024 3:33 pm | |
| 1st these are old style bulbs they get fairly hot, if your meter/gauges and horn works is not the fuse, not a short, if not check fuse "B", if burnt, replace, but it may fail again if there's a short somewhere ??, otherwise it could be brake levers, brake light switches, yes, they can both fail/get dirty contacts/loose connectors, usually not at the same time, you usually notice when 2nd one fails, a jumper across connectors on wires should illuminate brake light , the switch is the one with spades facing in on either side. Sometimes spraying switches with WD40, etc. can restore them, Good Luck. |
| | | GHM-PM Site Admin
Number of posts : 2606 Age : 71 Location : Bullhead City, AZ Points : 7427 Registration date : 2012-05-17
| Subject: Re: brake light Wed Jul 31, 2024 8:04 am | |
| WD40 is a light oil and not the best thing for electrical work. Most auto parts have specific electric switch cleaning sprays. That is what I prefer. Something like this:
https://www.maxwarehouse.com/products/crc-qd-electronic-cleaner-11-oz-1?variant=40279823745075&adlclid=79d5f902742b1092f7a89fa853fd2c4c&msclkid=79d5f902742b1092f7a89fa853fd2c4c |
| Subject: Re: brake light Wed Jul 31, 2024 11:27 am | |
| - GHM-PM wrote:
- WD40 is a light oil and not the best thing for electrical work. Most auto parts have specific electric switch cleaning sprays. That is what I prefer. Something like this:
https://www.maxwarehouse.com/products/crc-qd-electronic-cleaner-11-oz-1?variant=40279823745075&adlclid=79d5f902742b1092f7a89fa853fd2c4c&msclkid=79d5f902742b1092f7a89fa853fd2c4c Yes, you're right about "regular" WD40 been a poor choice strictly for cleaning electrical contacts, but "quick drying", "No lubricant", dedicated contact cleaners do little for stuck/rusted mechanical parts of the switch, WD40 IME is way better for that, it lubes/frees-up the mechanical portion of the switch, that usually causes the contacts failure. On a switch that sees frequent use WD40 residue is not really an issue as the lubricants are very volatile/short life. That's why WD40 is a better (not the best) for loosening rusty parts, but poor for lubricating. BTW, I have CRC on my shelf, only use on contacts. |
| Subject: Re: brake light Thu Aug 01, 2024 4:56 pm | |
| well ive tried fiddling with various things but as i hate electrics, i'm dropping it off with my local garage tomorrow to fix. they are very good usually |
| | | | brake light | |
