Number of posts : 179 Location : Lanark, UK Points : 3912 Registration date : 2014-09-27
Subject: front brake light Fri Nov 10, 2017 4:41 pm
I recently posted about front brake light switches failing, changed mine for the MOT and this week I noticed it wasnt working again so ordered another. Swapped it today and still not working, didnt have time or inclination to drag a meter out and check wiring but wondered if anyone else has seen this before ? Had just finished swapping a headlamp on my 08 megane so wasnt in the mood for deep investigation when im not using it much at the moment.
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10713 Registration date : 2009-06-12
Subject: Re: front brake light Fri Nov 10, 2017 5:06 pm
Just curious, but did you try shorting the brake light switch wires to determine that the switch was faulty? I managed to miss the switch terminal entirely by "reattaching" the switch wire harness between the wire-end terminal and the insulation cover when I replaced a brake switch.
Honda has legendary quality control. So the odds of a new switch being faulty are pretty slim.
Dave Weller Scooter Rider
Number of posts : 85 Location : Chatham Kent UK Points : 4826 Registration date : 2011-11-09
Subject: Re: front brake light Sat Nov 11, 2017 5:16 am
Last time I was touring Scotland my friend said I had no brake lights, front or back, both switches were faulty, they are not good quality. Two failing at about the same time is unusual , although it was being used after a long layoff.
Number of posts : 199 Age : 63 Location : Athens Greece Points : 4808 Registration date : 2012-04-05
Subject: Re: front brake light Sat Nov 11, 2017 1:49 pm
Those switches must never be greased,otherwise under cold or humidity tend to stick
